CUL8R Posted July 17, 2010 Share Posted July 17, 2010 Torque tube mount like I was saying I'd imagine.. Notice it most under hard acceleration/shifts Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 17, 2010 Share Posted July 17, 2010 Can get 185/65s for cheaps soon, brand new cheaper than the smallest 155 we do... I'd have to get in 60's as we dont make anything that size.. Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 Yeah theres a rubber mount where the torque tube mounts to the body and every chevette I have ever driven makes a bit of a bang sound when you drop the clutch or go between the gears pretty fast. It can be fixed by replacing this mount. Unless you are talking about just a random knock when driving. Not sure what that would be but maybe just check movement of exhaust because it gets pretty tight through the tunnel there. Is that the two rubber bushs that can be seen when looking from the diff foward, and are attached to the bottom side of the torque tube? And yeh, it only knocks when you are a bit quick on the clutch, and if you hammer it between the gears. Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 Can get 185/65s for cheaps soon, brand new cheaper than the smallest 155 we do... I'd have to get in 60's as we dont make anything that size.. 65s it is then haha. let me know if/when you can do a deal Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 17, 2010 Share Posted July 17, 2010 Nah those are steel spacers you're talking about. The torque tube rubber goes right around the torque tube and pressed steel is all around it which is what bolts to the floorpan. Hope that makes sense Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 it doesnt but i believe you haha, ill have a better look tomoro. Rekon Repco/Zac will have them? Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 17, 2010 Share Posted July 17, 2010 No, http://www.ozgemini.com/forums/non-tech ... hp?t=32379 But from memory the gemini ones are completely different to a chevettes , that and I've no idea in the slightest how to get the pressed steel apart from the rubber.. Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 the dude i got the car from said that it may have a gemini diff in it (is that possible?). If so, is there a easy way to tell? Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 17, 2010 Share Posted July 17, 2010 Yea chevettes are about this big l Gemini's are about this big l Seriously though bowl round one day whilst at work , poke your head under my car and compare, chevette's are piddly. Have a look at brads build thread and you'll see a stock one (his parts car from memory) Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 haha ok will do, cheers Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 oh and can i borrow those rear springs at some point? chur chur Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 17, 2010 Share Posted July 17, 2010 Oh yea If I remember to take them out of boot.. Could piss around one night at work, use tools/hoist there.. And yes its entirely possible that someone put a gemini diff into, almost a straight swap in.. Everything about the gemini diff is larger. Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 Sweet. Ill try get some pics of the diff, had a look at brads one, but i cant really remember what mine looks like haha. Quote Link to comment Share on other sites More sharing options...
mixmasterlex Posted July 17, 2010 Share Posted July 17, 2010 sweet wip. just gonna roll semi relable daily stylz? 4age on carbs? Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 yeh definitly daily. haha i wish. will just keep engine standard. Ive been spending too much money on cars haha Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted July 17, 2010 Share Posted July 17, 2010 get a tube of cheap as builders silicon and fill up the void around the 2 rubber support things, let it set over a couple of days. sorted! knock be gone its what they used to do on hotted up chevettes in blighty Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 17, 2010 Share Posted July 17, 2010 haha i was reading through some chevette forums and saw that done! cracked me up haha Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted July 17, 2010 Share Posted July 17, 2010 haha i was reading through some chevette forums and saw that done! cracked me up haha got some proper hardcoan/windscreen urethane here boes, use if to 'repair' engine mounts etc Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 18, 2010 Share Posted July 18, 2010 I put a Gem diff in mine. Cant be fucked imageshacking the pic of the two diffs but I have a pic on build thread. See page 5. http://nzgem.proboards.com/index.cgi?bo ... 451&page=5 Gaz Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 18, 2010 Share Posted July 18, 2010 cheers gaz, looks like mines just the standard one then. cheers Quote Link to comment Share on other sites More sharing options...
