reset springs vs lowering blocks
mk2escort
Hey was thinking about getting my escort lowered abit so was going to grab some blocks off trademe but after looking around abit been seeing abit about resetting the springs or something ?
so i just wanted to know whats does this mean is it better or cheaper than blocks in some way?
sorry for my lack of knowledge in all things mechanical :lol:
in in chch btw
Probably more of a Tech question really..but anyways..
http://www.springs.co.nz/index.html - These guys specialise in that kind of thing.
Pretty sure blocks are just a cheap way to lower, not the best way, just the cheapest.
Some info on block lowering: http://www.eatonsprings.com/blocks.htm
More info on leaf springs in general, seems to be pretty legit info.
http://www.eatonsprings.com/atqMainPage.htm
bellamy and east in christchurch will reset your leafs for $120 basically ready the next day. i would recommend this over blocks for a few reasons. firstly you can only legally lower 2" with blocks, but can go as low as your leafs will allow if you get them reset. mine ended up about 70mm lower. also reduces diff tramp, ie the whole diff rotating under hard acceleration, which can occur with blocks as the blocks act as a lever arm. also resetting leafs is visually a much tidier way of doing it.
im sure there are other reasons, but when it cost close to 100 for clocks and bolts (if you buy them) you may as well get the leafs reset instead.
hope this helps
Leaf resetting all the way.
Blocks a U bolts are gonna cost u the best part of $100 anyway, i got my leaf springs reset for $120, its just a better way to do it, can go down as much as u like etc
and u dont have to fluff around with u bolts and having horey looking blocks under your axle housing :lol:
my vote: reset them. not much more cost, and is way mroe solid
Pretty much exactly what this man said, blocks twist and tramp under torque/skids.
The only real advantage of blocks is that any one with a jack and a socket set can do it themselves and put it back to standard again any time.
I have 2" blocks and reset leaves in my 323 (standy motor) which is tucking the tyres in the back. I will be going to full reset leaves and caltrac bars once new motors in though
hope this helps
any chance of a place like this in AKL? have just got my hands on a van with flipped leafs and would rather have them reset + 2" blocks for a wof. Been told s.a.s in manukau will do it, but would be a few day turn around as opposed to one.
You gotta take the leaf springs out, and he does them from there, but if you were keen you could drive to my house, take em out, take them to this dude who does them, then when we get them back (around 3.5 hours later) chuck them in with the blocks..
Or just bring them round this side of town and take them to him, go to some shops or something for the afternoon and go pick them up
I was thinking about reseting the rear leafs in my corona but they are sitting pretty much flat as they are, i'm assuming they will invert.
Anyone know anything about the leafs in the rt84's, whether this is normal or not.
you can get the eyes inverted which should give you about 2" drop and still keep the shape....
snells springs in auckland do them aswell, but yea you gotta drop the springs in not the car 8)
