Simon Posted July 2, 2009 Share Posted July 2, 2009 Buy muy suzuki alto Capacity: 796cc Nominal bore: 68.5mm Stroke: 72.0mm Compression ratio: 8.7:1 Max power output: >29.5kW/39.5bhp @ 5500rpm Power output per litre: >37kW/49,7bhp Power to weight ratio: 64,1bhp/ton (616Kg) Max torque: 59 Nm @ 3000rpm Torque per litre: 74,1Nm Torque to weight ratio: 95,8Nm/ton Intake 31.6mm Exhaust 27.6 (valve head diameter) Rocker ratio: about 1.48 think its got like 40L tank and does 450km on full tank round town. (or something ridiculous / awesome) Quote Link to comment Share on other sites More sharing options...
Guest Posted July 2, 2009 Share Posted July 2, 2009 Max power output: >29.5kW/39.5bhp fuck that sounds about right, mine takes $40 to fill from empty? with 91. ive saved a bit of cash dailying it for the last month though, rules Quote Link to comment Share on other sites More sharing options...
Simon Posted July 2, 2009 Share Posted July 2, 2009 ^ Its seriously ftw. Just buy a daily driver with the least displacement you can find. And rego / wof out weighs fuel costs for the year. Fuck insurance. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 2, 2009 Author Share Posted July 2, 2009 yeah my morrie/austin is cheap to run - just whinging that my car uses so much fucking fuel when I do use it... need scooter.. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 2, 2009 Share Posted July 2, 2009 4.25km/L seems pretty fucked up to me. I was getting easily twice that from the 4m Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 3, 2009 Share Posted July 3, 2009 4.25km/L seems pretty fucked up to me. I was getting easily twice that from the 4m 4m was injected? . but yuh kk that ludacris , unfortunatly i dont know nothing bout carbs , spech those ones lol Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 3, 2009 Share Posted July 3, 2009 4m = uneconomic poos jap carb. thety run way better economy with a weber. i easily double kk's mileage in my crown Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 3, 2009 Share Posted July 3, 2009 4m = uneconomic poos jap carb. Yup, and mine had a vacuum leak to go with it, making it near impossible to tune Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 3, 2009 Share Posted July 3, 2009 i hard doing burnouts cures it aye Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 4, 2009 Share Posted July 4, 2009 i hard doing burnouts cures it aye ^ agreed. I even read it in haynes. they had a hand drawn picture of a bald guy with a mole above his left eye doing a phat skid Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 4, 2009 Share Posted July 4, 2009 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 27, 2009 Author Share Posted July 27, 2009 Jesus Hemi - you actually are the greatest artist I have ever met - how you don't draw for Disney..... LOL Anyways -I have fitted the wideband today (Thanks Sentra - muah xoxox lubs)- ran it at my prior uneconomical settings - AFR ranged from 10:1 - 15:1 (idle was 10:1) but mostly hovered around the 11:1 mark - from previous information I know it used 42.5litres in 270-280Km at these settings Changed the needle to jet height by 2.5 turns per carb - ended up at an approx average of 14:1 (idle was 12.5:1) Wound it back .5 a turn and ended up with an average of 13:1 - range was mainly between 11.5:1 and 15.5:1 (idle 11:1 I will leave it as these last settings for now and will fill fuel tank tommorow morning and run a tank through before trip to palmy on Friday night - will report back once again after the weekend.. fingers crossed it won't cripple me still.. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 27, 2009 Share Posted July 27, 2009 that seems as close to decent as you'll likely get it. interested to see what happens. yay for s.u style carbs. so men. Quote Link to comment Share on other sites More sharing options...
sentra Posted July 30, 2009 Share Posted July 30, 2009 i jusrt had a flashback when i picked up ur wangon for roadtriop we just said goodbye to you and were dropping manu back to his floatcrib and the brakes locked on at the end of ur bus works road and we were stuck for a while wondering what to do then it started moving again mabey disconnect your brakes and check your economy again to rule that out? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 30, 2009 Author Share Posted July 30, 2009 Good thought - but overhauled all the brakes and fixed that problem long ago.. cheers for the input - will see you Jolly Rogers tommorow night for some mixing of drinks and slapping of backs.. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 30, 2009 Share Posted July 30, 2009 Based on the fact that some small areas of the south coast of Peru were visible when you drove past my house 25 minutes ago I would suggest that the alternator must be sucking around 42kw to power your headlights. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 30, 2009 Author Share Posted July 30, 2009 yeah and one of the headlights ain't working either.. damn it Quote Link to comment Share on other sites More sharing options...
sholdowa Posted July 31, 2009 Share Posted July 31, 2009 havent read through the whole thread, so it might have been suggested already... but could it be something unrelated, like a brake dragging?? Quote Link to comment Share on other sites More sharing options...
efp0wa Posted August 3, 2009 Share Posted August 3, 2009 Hows your PCV valve? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted August 4, 2009 Author Share Posted August 4, 2009 Doesn't have a PCV valve as such - though it does have a vent in the rocker cover that just evnts to atmosphere.. (normally goes to the airfilter) Quote Link to comment Share on other sites More sharing options...
