bubblegoose Posted April 21, 2009 Share Posted April 21, 2009 sad times stripped the b1600 diff down, trying to get the axle out of the hub/bearing bit but it wont budge. the inner race wont come off the axle no matter how much me and my hammer ask it to i don't have access to a press big enough to put the whole shaft in what the hell do i do (that i don't have to pay for) Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 21, 2009 Share Posted April 21, 2009 Cut it off with angle grinder... carefully. Dont cut right through but almost. Then use cold chisel to finish. Wear gloves and glasses as the shit is mega hard and brittle. Ask UJ Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted April 21, 2009 Share Posted April 21, 2009 And cos it's so hard, the sparks are hot as fuck. You can also do it with the brass hacksaw, but you need to be carefull not to fuck the axle. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 21, 2009 Author Share Posted April 21, 2009 cant its the inner race so it wont come out of the bearing (taper stops it), we've had an argument so its sitting in the garage and ive stormed off will return tomorrow for more hammer time/dremmel time Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted April 21, 2009 Share Posted April 21, 2009 is it still in the diff? Quote Link to comment Share on other sites More sharing options...
johnnyboy0212 Posted April 21, 2009 Share Posted April 21, 2009 a desent cold chisel and a good large hammer.by far one of the best ways to get the sucker off. its not hard, be ruthless and show no fear! good luck. Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 21, 2009 Share Posted April 21, 2009 Cut it off with angle grinder... carefully. Dont cut right through but almost. Then use cold chisel to finish. Wear gloves and glasses as the shit is mega hard and brittle. Ask UJ Fuck yes.Bits of 35 year old bearing race emmbedded beneath the flesh or in the cornea are both annoying and difficult to remove without medical assistance. Gloves and glasses yo. Especially when cold chiseling. Seriously. Quote Link to comment Share on other sites More sharing options...
Gaz Posted April 22, 2009 Share Posted April 22, 2009 Plus earmuscles Hammer on steel can = loud Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted April 22, 2009 Share Posted April 22, 2009 +1 for grinding the majority of then chisel to finish. Had to do this to both front and rear bearings on my gaydub. Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 22, 2009 Share Posted April 22, 2009 +1 for grinding the majority of then chisel to finish.Had to do this to both front and rear bearings on my gaydub. more shit needs to be fully floating , make life that much easier i used gas then chisel , but im gonna assume you dont have that luxury so as per above with the grinding Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 22, 2009 Author Share Posted April 22, 2009 picture might help explain my problem as you can see ive had alot of heat on the inner race and a large hammer not really enough room for a grinder Quote Link to comment Share on other sites More sharing options...
kyteler Posted April 22, 2009 Share Posted April 22, 2009 Can you not set the rear against a vice and punch the shaft through from the other side? Quote Link to comment Share on other sites More sharing options...
Unclejake Posted April 22, 2009 Share Posted April 22, 2009 Twin leading shoe on a rear brake? That shit is awesome. Quote Link to comment Share on other sites More sharing options...
boso Posted April 22, 2009 Share Posted April 22, 2009 no eny one with a gas axe aka "Blue Tongue Lizard" and heat the iner race up and hit it out or just cut the iner race with the gas axe and it will fall off good luck Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 22, 2009 Share Posted April 22, 2009 no eny one with a gas axe aka "Blue Tongue Lizard" and heat the iner race up and hit it out or just cut the iner race with the gas axe and it will fall off good luck the inner race probably wont fall of (touch wood but none of the ones ive had have) and dont cut the whole thing off with e gas axe leave the last bit for the chisel because the chances are the stream of molten steel will go straight through the axle Quote Link to comment Share on other sites More sharing options...
boso Posted April 22, 2009 Share Posted April 22, 2009 I use the gas the hole way u just got to be quick enough not to get to match heat in to the axle i cut all the bearing off the axles with the gas at work works for me Quote Link to comment Share on other sites More sharing options...
Hemi Posted April 22, 2009 Share Posted April 22, 2009 I use the gas the hole way u just got to be quick enough not to get to match heat in to the axle i cut all the bearing off the axles with the gas at work works for me this is getting off topic mang but not everyone has the gas skills you have so id rather tell him to gas cut through the majority and then use the chisel . reguardless i dont think he has a gas axe so it dosnt matter Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 22, 2009 Author Share Posted April 22, 2009 ive heated the inner race up fucking super hot (notice in the picture the edge has melted) still wont come off its too stuck to smash it out (that was my first trick) ive started grinding off the lip on the inner race to pop out the rollers see if i can get the axle out that way but man this is fucking me off! Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted April 22, 2009 Author Share Posted April 22, 2009 Twin leading shoe on a rear brake?That shit is awesome. it was, when/if i ever get it finished it will have the rear brakes from a 2009 corolla Quote Link to comment Share on other sites More sharing options...
kpr Posted April 22, 2009 Share Posted April 22, 2009 you need to press that shit off. Quote Link to comment Share on other sites More sharing options...
