boso
New Members
boso's Achievements
Member
Member (2/5)
0
  1. the shaking wood be no problem use them all the time in plumbing up excavator attachments and they get a very hard life. maybe a return spring on the brake pedal and a common brake fluid reservoir so u dont get one reservoir over filling and one emptying. what is this set up going on?
  2. Shuttle valve best option i think because it will let the pressure return to tank as oil aways takes the esay path of flow. An one way check valve in each line wont work as both checks will block off wen u let pressure off and lock brake up. you can buy them from enzed or hydraulink go into a place like them tell them wot u wont to do they shod sort you out. cut away of a Shuttle valve
  3. 32mm socket is prity match the same as 1 1/4" socket use it all the time instead of a 32mm. Will work in both 12point and 6 point
  4. I use the gas the hole way u just got to be quick enough not to get to match heat in to the axle i cut all the bearing off the axles with the gas at work works for me
  5. no eny one with a gas axe aka "Blue Tongue Lizard" and heat the iner race up and hit it out or just cut the iner race with the gas axe and it will fall off good luck
