Nothing's RX-DX
filthy one
  • Replies 68
How are you going about mounting the engine?
Are you going to maout it way foward & save your gearbox tunnel but screw up the "mean" handling of the "Phat DX"
Or are you going to cut your tunnel & mount the bitch way back?
You using the series 5 mounts or you going to run a 1st gen front cover & mount of the front of the block??
Nah engine is getting shoved right down Kermits throat. I had already played round with the fitting abit on the other shell and have it sitting so the series 5 mounts sit back on the cross member. I would put it back even further, but then run into trouble with the exhaust ports being right where the steering column meets the rack, and I have no desire to mess with the position of the rack. As it is, the back of the engine sits basically directly inline with the firewall, so it is pretty far back anyway. Will have to make up a custom exhaust manifold to space the turbo out and make room for the wastegate and exhaust to somehow get past the column and under the car...
Nah its a s5 rear, with a Turbonetics .60 compressor. So will still be responsive but abit more grunt. Im not after big power, although the engine could handle it with the mods its had, but the 300+ rwhp will be more than enough to get into trouble in a sub 900kg car...
plus 50kg of wanga. put up a pic of new wheels asshole
Anybody who has used dry ice to get rid of the sound deadening, did you just spread it out on the floor pan, or stick it in something like a bag?
Gonna have to go thru this mission again haha...
Just spread it around, wear welding gloves or something too. Fuck chiseling the shit off, dry ice makes it so much quicker and cleaner.
