kyteler Posted May 28, 2008 Share Posted May 28, 2008 • the wheels: – are a known and reputable brand non-OE item, and – would be considered an appropriate fitment for the vehicle type by the wheel manufacturer, and – are not modified, and – spacers or adaptors are not fitted. • the tyre tread: – does not protrude beyond the unmodified original body panels (including unmodifi ed factory-fitted mudguard extensions), or – protrudes beyond the unmodified original body panels, but is covered by aftermarket or modified mudguard extensions or modified body panels, and the track width has increased by no more than 25 mm from OE. ^ So, it says as long as you're <25mm increased track from Original Equipment specifications and the tyre is covered by the either the Original body panel or an aftermarket extension. (such as a bolt on flare.) It does NOT require LVVC Which is on Table 10-1-1, page General Vehicle Page 10-1-4 Quote Link to comment Share on other sites More sharing options...
durty Posted May 28, 2008 Share Posted May 28, 2008 • the wheels: – are a known and reputable brand non-OE item, and – would be considered an appropriate fitment for the vehicle type by the wheel manufacturer, and – are not modified, and – spacers or adaptors are not fitted. • the tyre tread: – does not protrude beyond the unmodified original body panels (including unmodifi ed factory-fitted mudguard extensions), or – protrudes beyond the unmodified original body panels, but is covered by aftermarket or modified mudguard extensions or modified body panels, and the track width has increased by no more than 25 mm from OE. ^ So, it says as long as you're <25mm increased track from Original Equipment specifications and the tyre is covered by the either the Original body panel or an aftermarket extension. (such as a bolt on flare.) It does NOT require LVVC Which is on Table 10-1-1, page General Vehicle Page 10-1-4 cheers boe, me = too lazy to type it out stz Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 28, 2008 Share Posted May 28, 2008 Fuck that, I didn't type it out... you can just select the text. Quote Link to comment Share on other sites More sharing options...
durty Posted May 28, 2008 Share Posted May 28, 2008 lol, im too lazy to even do that, in fact the only reason im still posting is to up my post count Quote Link to comment Share on other sites More sharing options...
FoNX Posted May 28, 2008 Share Posted May 28, 2008 Super helpful thanks guys, will have to take some measurements and compare against the original track width. Pretty sure itll be more than 25 mm increase though Quote Link to comment Share on other sites More sharing options...
durty Posted May 28, 2008 Share Posted May 28, 2008 just chuck your standards back on for the wof if the inspektor is being a cunt Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted May 28, 2008 Share Posted May 28, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
Rusted Posted June 6, 2008 Share Posted June 6, 2008 Extaust law pasted two days ago, Who's got the graft? Quote Link to comment Share on other sites More sharing options...
Jase Posted June 9, 2008 Share Posted June 9, 2008 haha lol is that 125mm or 25mm coz i gained a bit with the 9s ah well cert should cover it Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 18, 2008 Share Posted June 18, 2008 Few QuestionsWith my Box going form Auto to a Manual is anyone gunna care WOF time? Also im just gunna be switching my Vin numbers over from my old car to the new one using the same plates. Should i really have any problems? No ideas then? Quote Link to comment Share on other sites More sharing options...
kyteler Posted June 18, 2008 Share Posted June 18, 2008 As long as you used all factory components during the manual conversion you should be fine, if you had to fab a gearbox crossmember or fab a mounting point, you'll need cert. Also, you've got online documentation of changing over to another car. Really you should be taking the car through a re-vin and re-reg process because it's not the same car. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 22, 2008 Share Posted June 22, 2008 Yea i know i should be, but if i roll up for a wof and they don't say anything i shouldn't really worry about it? Revin re reg etc will be like 1K??? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2008 Share Posted June 22, 2008 if the colour matches on the rego and it's not that old red paint you'll likely be sweet. plus don't go to some anal cunt, and be a gc come wof time and you'll be good to go. Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 22, 2008 Share Posted June 22, 2008 if the colour matches on the rego and it's not that old red paint you'll likely be sweet.plus don't go to some anal cunt, and be a gc come wof time and you'll be good to go. Not a good idea to roll up with, Red roof, Front and rear quater panels, Creme Doors, Boot and bonet then lol. I always go to VTNZ, as most garages and workshops just want work. Maybe a good idea to paint the orange panels white or something with paint bombs before the warrent???? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2008 Share Posted June 22, 2008 you're likely going to have to be abit moer legit than that. maybe go talk to your normal wof guy and tell him the deal. they might be unworried Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 22, 2008 Share Posted June 22, 2008 Will do, thanks cam Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2008 Share Posted June 22, 2008 Yeah I've done a 'reshell' on a mini before (changed plates and tags) and no cunt cared. old man's done one or two like that too. 100% kosher, jsut the reg'd shells were donkies and the dereg ones were mean Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 22, 2008 Share Posted June 22, 2008 YeahI've done a 'reshell' on a mini before (changed plates and tags) and no cunt cared. old man's done one or two like that too. 100% kosher, jsut the reg'd shells were donkies and the dereg ones were mean Same here, just gota fix up some panel rust Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 22, 2008 Share Posted June 22, 2008 cone revins only like 3hundy from what i hear anywho Quote Link to comment Share on other sites More sharing options...
NewGuy Posted June 22, 2008 Share Posted June 22, 2008 Thinking i might pull all the bright works off the car, Lights etc as well. Rub it down with my buffer and primer it all over. So its at least all one color. Quote Link to comment Share on other sites More sharing options...
