Nominal
Everything posted by Nominal
  1. If it's dereg then the plate means nothing. Registered owner doesn't equal legal ownership anyway. All you should need is a receipt from the current owner I think, then work through the entry cert process
  2. I thought you had a Falcon wagon? Or build a Dynafari?
  3. Steeb always has dudes available.
  4. Have you been reading the unofficial lvvta page on FB again? Man that place has some numpties.
  5. What, you mean I can't run 185 radials on my Morris Minor any more????????
  6. I assume it would have been spot welded at the top and bottom flanges. A spot weld cutter would probably get it off.
  7. How would you manage to weld all the existing parts to the new T piece? They all need to be connected for strength I assume. Apparently looks like this So there should be 3 layers in the sandwich, flange on floor, stiffener and outer sill, the inner sill is flanged to the floor. If this is a proper keeper car (which it seems to be) you should do a proper job, remove the outer sill, and stiffener, the cut back into the inner sill and floor enough to weld on new flange pieces, them replace the stiffener (which looks just flat, maybe just weld a new bottom edge on), then replace the outer sill (again you might be able to just weld a new lower flange on it.
  8. How do you know where to put all the bits / loom etc? Working off a manual, or the other car?
  9. They are such teeny cars, can't be much built in the last 30 years that is so small and RWD IRS?
  10. Just get an MX5? What are you trying to achieve with a 200hp GT6? I've found that simpler projects are more likely to get done in a reasonable time and I somewhat regret launching an 'all out' project.
  11. What's happened with the panzer wagon - pushed to the unloved corner?
  12. My first 'company car', then I left the company 1996-2010
  13. Yeah, that's about how often I use it too.
  14. Oldschool Gas. I better do some more cutting $20/month not too bad I suppose.
  15. Engine hasn't turned since 1987? That's going to be a challenge. Have @ajg193 or someone make you something that you can bolt in place of the crank pully and weld and old 3/4 drive socket to it? 1/2" might not be enough
  16. How thick is the housing where the caliper bracket is welded? Seems odd that there would be a hole right though that could leak? A good degrease / brake clean session should allow it to be zapped with a mig. Maybe tickle it up with a grinder first to identify the hole?
  17. You know you need a shiny underside when its jacked up, right?
  18. The pics that are gone are FB links so not permanent usually. Best way to make them permanent is to upload them to the forum.
  19. Pallet packing made me twitch too.
  20. There is a lot more chat in the welding thread. If you really want the cheapest you'll have to do some legwork. I just go with the BOC D-plan coz easy, not big outlay to buy the bottle. Look at Bunnings too. e.g.
  21. Hydrofluoric acid is nasty stuff, can go right through your skin.
  22. Maybe you need to modify the airflow at the back of the car? Couple of options I thought of.
  23. I dunno what the problem is really
  24. Get some new wheels?
