About nvmyvl
- Birthday 02/02/1979
Gender
Male
Local Area
Auckland
894 profile views
nvmyvl's Achievements
Advanced Member (3/5)
726
What year is yours @Muncie?? Mines a 1999 Gsix.. found a couple of drive belts last night in the box of bits that were with the Kirby.. got it working for the first time in 15 years or so. I've got a plastic caddy with a heap of attachments, a flexi hose and the wet carpet cleaning head. Thought there was more attachments, but they must of been thrown out over the last couple of house moves. I really need to give it a Autosol like you did.. mines looking like it's been sitting outside under a tree for 10 years.
I got a Kirby in the garage.. just need a new drive belt for it. Got a few attachments as well. Must dig it out
Just saw this on Facebook for sale again.. no stickers tho...
LG's Old Pest Brewery - setting up from scratch...
nvmyvl replied to Lord Gruntfuttock's topic in Other Projects
I got a bottle washer setup. Best thing I ever made.. pulled most of it apart when I moved, and never put it back together. -
I used to use a single flute end mill for ACM on the CNC Router that I ran for a few years. Spindle speed was up there from memory.. over 20000rpm, and feed rates were about 1800mm a minute.
nvmyvl replied to h4nd's topic in Other Projects
- 1289 replies
- 16
Made an upgraded bait launcher / spud gun. Should work well Twin 100mm stainless tanks, each able to be isolated separately. 50mm stainless irrigation valve, modified to be released via push button trigger. Its a tad overkill haha.- 1289 replies
- 27
Never heard of freezing it first.. and I machined the shit for 16 years. Depending on the hardness, then tool steel is the best To use. If you go see the boys at LEP in onehunga, they will look after you. Plus they pour polyurethane there, so if you had originals, then they can make a mould from them and then pour as many as you like
BBQ Build - Attempt to build a reverse flow offset smoker
nvmyvl replied to Taistorm's topic in Other Projects
Looking good.. May I suggest that you get a fire going in it as soon as possible. You are going to need to set the paint well, before its first use.. the smell from the high heat black is pretty horrendous. It will burn off tho, and then you will be all good, till next year, when you will need to paint it again. Also check on the can, but with the pot belly black that I used from bunnings, it said that you have to recoat within 16 hours, otherwise leave for 7 days then recoat. I didn't follow the instruction when I painted my spit, and it all bubbled off in the first burn. -
Cheers man, not sure wat to do yet.. I've got a couple of mutton roasts in the freezer, from some old girl I knocked off a few months ago.. may try that, or go the standard ribs or brisket. It's been running for 10.5 hours so far.. and its been pretty consistent between 250F and 270F.. had it cranked up to 435F for a bit, just to try and set the pot belly black paint. -
Built me an UDS (Ugly Drum Smoker).. Got an old drum and burnt it out for a few hours, sanded it, pot belly blacked out.. made 4 intakes out of copper pipe.. exhaust is stainless.. Running it for the first time today, to season it.. seems to be pretty easy to keep within temp range for low and slow..- 1289 replies
- 20
Just chuck a foot valve on the suction side of the pump.. that way you wont loose prime
Hey I got 3 lengths @ 2000mm here.. got surface rust on it, but that's easy to clean off.. your welcome to a piece if you still want it.. I'm in Drury, so may be able to get it on somebody going down your way, if somebody is..
How much do you need for the axle?? I got a couple of lengths in my shed of 50 x 50 x 6mm wall.. perfect for welding stubs into
