  • Replies 86
FWIW, my experience has been that on current fuels once a plug is fouled you can't bring it back. Solvent, abrasive blast or heat, none work.
Not like the old days where solvent worked 99% of the time.
Yup, these o rings are toast.
20240528_160213
Quick visit to seal imports here in Hamilton and 7 bucks later.
20240528_151217
A little amount of grease to help them slide in. Cause they were most definitely a snug fit this time round and they were all together again.
20240528_154125
Back on
And all running again.
VideoCapture_20240528-181223
Hope the weather does something great and I can head out for a ride double check it's running good on the open road.
Mates also said I could use his balancer to balance the carbs. So might take him up on that, probably shoot to his house and do it there as he has a way better set up and plenty of garage space.
  • Like 8
Those were always short of ground clearance. Rumor had the Wellington M/C bikes using stiffer springs. Learn to hang off a bit. It'll help.
18 hours ago, 64valiant said:
20240712_224950
i mean it worked and stopped well, but nice to know that its grabbing a bunch more now.
The thing you gotta watch there is what happens when it wears to the point that the pads touch each other and no longer grab the disc.
I really like this bike. Keep it up!
Yeah i had that in mind and a reason why i wanted the bigger ones@anglia4, get use of the full pad now that ive got the bigger discs.
Old discs yeeted into the bin with those pads.
Old girl seems to be burning some oil as well, might need to strip it down and do some oil rings.
Or ill just top it up with oil for the mean time.
Excellent work bro, such a cool bike and such a cool story. I grew up on the back of my old man's bike, my brother's both have bikes, one a night-rod Harley, the other a 78' 900SS, and I'm pining for one now! Old man only just stopped riding a couple years ago at 83 years old, so I think I've got a couple years left!
4 hours ago, GregT said:
Your oil consumption could well be valve stem seals. Known to get hard with age. It is possible to change them in place.
Have also been suggested to use mineral oil instead of synthetic in it.
I'll try that 1st and see what happens and then valve stem seals are up next.
Also will give it a compression test before I go do the valve stem seals to see if it's also rings
