kicker Posted October 4, 2018 Posted October 4, 2018 Just sorting a trailer for my dad and it has an old disc brake setup on it. It looks like I'll be replacing the calipers as they are fucked, I assume they are Trojan mk2's but have a question, everyone seems to refer to the mk2s as having a 100mm mount but I measure 102ish on the trailer (which is close to 4"), is it just a way of differentiating them and not actually 100mm? The other mount is referred to as 90mm and I'm wondering if it is actually 88.9mm (which would be 3.5"). Quote
My name is Russell Posted October 4, 2018 Posted October 4, 2018 . . . I can't help sorry In saying that I have some new Trojan calipers on my trailer I could measure what they are? 2 1 Quote
JoKer Posted October 4, 2018 Posted October 4, 2018 TTIUWOP! old Barry's made all sorts of brake setups on old trailers mang Quote
Bling Posted October 4, 2018 Posted October 4, 2018 Probably after a pic of the caliper this whole thread is about. 3 Quote
kicker Posted October 4, 2018 Author Posted October 4, 2018 Definitely Trojan calipers and as mentioned, bolt hole spacing is around 102mm/4" I asked a person selling Mk2 calipers and they seemed sure they were 100mm spacing but I didn't think 70's NZ was very metric so still not sure Quote
kicker Posted October 4, 2018 Author Posted October 4, 2018 Just looking at the pads that came out and they look like the Mk1 pads (square) so maybe that's what they are. 1 Quote
Get it done Posted October 4, 2018 Posted October 4, 2018 Pretty sure mk2 has the rib lines on the top. Quote
smokin'joe Posted October 4, 2018 Posted October 4, 2018 should be easy enough to re-kit them, as they will be a generic piston/seal i'd be more concerned about the wheel bearings, as the Trojan ones on my trailer were MK2? Zepher and were over $400 per hub to replace, if they were obtainable 1 Quote
kicker Posted October 4, 2018 Author Posted October 4, 2018 Yeah, can still get pads and seals from manufacturer but would have to hunt out some pistons as they seem to be no longer available. Bearings are easy, they are common ones thankfully. 1 Quote
Kiwibirdman Posted October 10, 2018 Posted October 10, 2018 Sorry to Hi Jack this, I have the MK 2 calipers on my caravan, are new discs available, the VTNZ WOF guy got excited about the minor pitting on the disc face. Quote
kicker Posted October 10, 2018 Author Posted October 10, 2018 You can get new discs, I assume you have the single unit hub and disc setup? The disc surface of the new zinc plated cast iron ones is a bit rough, probably worse than your pitted OG items 1 Quote
Get it done Posted October 10, 2018 Posted October 10, 2018 Disks are available last time I checked, single piece hub and disk. Heat dissipation from disk to hub is what stuffs the bearings, be sure to put a bead of sealant around the dust cap too as it will pull the moisture in from this side first turning the grease milky. Quote
Get it done Posted October 10, 2018 Posted October 10, 2018 Also i think cm trailers do a direct replacement, could be wrong though. Quote
AllTorque Posted October 11, 2018 Posted October 11, 2018 Take them in to CDL’s work and they will tell you everything you need to know. They probably have some NOS pistons tucked up on the top shelf of the smoko room. 2 Quote
Kiwibirdman Posted October 12, 2018 Posted October 12, 2018 On 10/10/2018 at 19:15, Get it done said: Disks are available last time I checked, single piece hub and disk. Heat dissipation from disk to hub is what stuffs the bearings, be sure to put a bead of sealant around the dust cap too as it will pull the moisture in from this side first turning the grease milky. Yes they are the single piece ones. The don't look to different to some old LH torana ones I have lying around. Quote
