  • Replies 141
Also first test ride was a ooge success, runs really well now, and all the little changes have made it much nicer to ride. I just need to grease and adjust the head set bearings and that's about it.
It's quite talkey, but does indeed max out around 90/95 on the flat, seems like it's running out of revs, so might try one of the smaller cogs and see if it has enough grunt to pull 100+.
Pretty happy with it tbh. Excellent.
On 05/02/2024 at 19:55, tortron said:
Jialing one will work/it's the same thing.
Otherwise look at Xl185 ones
This place doesn't seem to exist anymore. The internet told me Agtorque was an agent for Jialing, but they aren't, so not sure if there is an agent in NZ anymore? Had a hoon on Ali & ebay but no luck so far.
Oh damn, maybe a covid victim. I had his number somewhere.
If you look for the Honda XL parts on amazon, Ebay, or aliexpress you should find the same parts
On 12/03/2024 at 14:05, Vintage Grumble said:
Have done a few very short rides on this bad boy, and its running pretty damn good. Its quite nice to ride also, which is a bonus. At nats I did a 75km trip from nats HQ to a museum in Cambridge, and just to be safe, I decided to re-fill it before departing for nats HQ on the return trip. It went onto reserve in the middle of the road in front of the service station, which was a bit of a surprise, as I was told it would do 200km on a tank (6L) but had only managed 75ish. That's around 8L/100km, which isn't great. J5's bike which is very similar, and was pulling the same speeds, and is only 15cc smaller in capacity, used just over half as much from memory, so somethings not quite right. Its defiantly running rich, and often smells a bit gasey, but I cant find gas leaking out anywhere. Will dropping the needle make a noticeable difference? Cant really think of anything else to check/change?
I did manage to hit the metric ton in a two lane flat express way race with J5 though, so that's a new PB.
Also also, a person on TM who confirmed they had both racks I need, then ghosted me super hard when I tried to buy them. BUT I mentioned to a customer that I yarn to about shit old bikes, what I was after, said his best mate apparently has at least 6x CT200's laying around, so he is actively trying to source the racks for me, excite.
Pic4fred:
Regards, VG.
Here's a thought, is the petrol tank crossover pipe blocked? Would only give you half the usable tank capacity which would appear similar as using shitloads of fuel...
11 minutes ago, anglia4 said:
Checked the state of the air filter?
Yeh the filter is mint, looks to be new. It doesn't need any choke to start, so I'm fairly sure its running rich. Smells a bit rich too. I'll start by dropping the needle down a bit and see what happens.
  • 4 months later...
21 hours ago, Vintage Grumble said:
Gave up trying to get factory racks for the CT, so slapped together a home made abomination from a random rack J5 gave me, with donor parts from one of the free Jialing farm bike racks I got from old mate in the hills. Welding poorly prepared (i.e. still had shitty powder coat on it) Chineseium steel was quite splatty. I also recycled rack off cuts and hung the lovely indicators J5 donated to me. (from an ER suzuki I guess?) Looks low at the back in pics, but is level IRL.
Then made a mount from more rack off cuts to hang a china rotapax off. I got two of them, but exhaust made it too hard to hang one either side.
I also modified the OG indicator brackets at the front to take the new units,
The barry spec mounting and wiring for the old indicators.
Then I investigated the muffler, the last baffle was shot to shit, it had lots of rust holes that had been filled with some putty, and the outlet was quite haggard. So I cut off the last section, fished out the remains of the baffle, then found a bit of tube exactly the right size and welded that on. Filled all the rust holes with weld. And then put on a silly looking little outlet pipe. Much better.
So just need to paint the rack and muffler, wire in the indicators, and then I can try remedy the nasty fuel consumption.
Regards, VG.
Definitely ER indicators. Local Suzuki dealer had them for $10/pair for years after keeping them from all the farm bikes. I guess supplies must be drying up by now.
Extra dull update due to trying to look like I'm doing something at work. Rode the CT around until it ran out of gas. I did nearly all open road at about 85-90kmh, with a bit of slow sandy off roading. It did 162km on the 6.2L tank, which is about double what it did last time (less than 80km, but was all up big ass hills and WOT express way racing) So if I'm getting 26km/L, with my little extra 5L container, I should have a total range of about 290km. One thing that did LOL me, was I put it onto reserve, and got about 3km before it completely ran out of gas, so luckily I had the back up. The main tube in the tank must be missing or something, so its as low as the reserve tube.
Anyways, pic for Fred, me cruising for bitches,
465787296_9081986378479748_4678564560204
  • 1 year later...
On 28/05/2018 at 21:46, Vintage Grumble said:
So after riding J5's CT110, I wanted in on that action. But CT's often go for more than I wanted to pay, so I repeatedly bid (Postal places seem to get rid of them around 60K kms) on its retarded cousin, the NBC110 (Super cub II) until I got one for a reasonable price. Its an ex postie bike (NBC = postie only model) from Welly, and it was in pretty good nick. Its of 2013 vintage, and is injected. Yes, 110cc of air cooled EFI madness. I gave it a bit of a clean up, and blasted round on it for a while. It had a bit of a shudder under acceleration, so opened the engine to replace the clutch plates. Turned out the centrifugal clutch drum and shoes were knackered also. I also then spotted one of the gear box bearings was well stuffed, so decided to pull the engine out, and replace most of the bearings (didn't do crank or cam bearings) and seals. While it was apart I got a recall notice from Honda, for the gearbox counter shaft, which was well timed I guess. I got all the new bits, and slapped it back together, and it ran beautifully, much much smoother. Just after this it got recalled again, and was fitted with a new fuel pump. I fitted cheap knoblies, and started riding it all over the place. Including the 600+km trip around the coast.
TL/DR, well here's some random pics of said bike,
Some time later (just the other day), I purchased a second bike that is exactly the same, but its missing an engine side cover/clutches/exhaust/foot pegs. The rest of its still in pretty good nick, so my very rough plan is to:
Remove bung engine and all EFI gear, purchase and install big block carbed engine, build or buy custom exhaust, lower it, fit flatter/lower handle bars, change huge gauge cluster for smaller unit, remount headlight, generally make it look sleeker/more stylish/sportier, try not to ruin everything.
Also big fanks to @sentra for collecting my number two, and letting me taste his meat.
Thanks for dropping by!
Regards, VG.
Thread dredge @Vintage Grumble
May I enquire, did you have to decarbon the head/exhaust port when you gave the might and venerable Green NBC110 of destiny the extensive birthday shown in the pictures?
Asking because @Sungai Sungai recently acquired a similarly powered bike, and his port was coked up harder than snoop doggs bong.
Also because the NBC you sold me seems to go just a little bit better than other bikes of a similar nature?
Good day to you Sir. I dont remember TBH, but I think I would have cleaned the head/ports out, Im usually pretty OCD about that stuff. The real reason it runs so good is because its received my special touch 😉
