I hope you bring it to next OS drag day
Are these the ones that play doort noises thru the speakers or something like that when giving the jandal?
I got it just before the last drag day, did consider bringing it along. Will very likely bring it to the next one for a hoon.
I'm not sure about the doort noise thing, i'm fairly confident it doesn't use the speakers, but it may have a tube that comes into/aims at the cabin? It doorts pretty darn well over 4g.
3 minutes ago, HighLUX said:
Weld up the e diff and see if Larry likes it
LSD's from the 2009 on-wards ones are a common upgrade. Welding seems like a better option than the TRD nugget, which is around $5G, yikes.
The first thing on the list of tidy ups, was to fix the gash in the left side skirt. I wipped it off, plastic welded it back together, applied a tiny bit of bog, and had it painted. The paint actually came out pretty good, amazingly.
Only a little thang, but makes Larry much less self conscious.
I also did an oil + filter change, nice and easy to do, and I'm glad I get oil cheap, because 10 litres of full synthetic 5w30 ain't cheap. I changed the plugs too, also not cheap, and took awhile, not a ton of room around the side of the engine.
Next I need to fix a door card issue which annoys my OCD.
Thanks for dropping in.
Regards, VG.
4 hours ago, kyteler said:
Get plugs from rockauto.
I tried to convince my old man to buy one based off your yarns.
I have a few automotive supplies through work, so got the plugs for $22ea as apposed to the $46ea retail price, but yeh must remember to check Rock Auto for that sort of thing.
I can highly recommend a Larry, I like this thing a lot. If he's got the coin, a 2010+ one would be the go, as they have an LSD and slightly softer springs, which might be better on NZs shitty roads.
30 minutes ago, kyteler said:
We get jacked on plug prices here thanks to the distributor.
Was that an ignition system pun?
  • Thanks 2
  • Haha 1
On 5/17/2018 at 09:28, kyteler said:
You're onto it.  I thought there may have been a little resistance but seems as though it found its way ohm.
That pun made me gag.
  • 1 year later...
