SOHC Posted August 17, 2015 Share Posted August 17, 2015 I have a clutch release leaver that runs on needle bearings witch is rooted on both bearing surfaces, its from a motorcycle and isn't obtainable anymore. What is a suitable gas welding rod I could use to build it up with? 2 Quote Link to comment Share on other sites More sharing options...
Testament Posted August 17, 2015 Share Posted August 17, 2015 I think machining a new shaft, cutting that one off and welding the new shaft to the arm would be a better and easier option. 7 Quote Link to comment Share on other sites More sharing options...
sidewaysickness Posted August 17, 2015 Share Posted August 17, 2015 Speedy sleeves for speedy fix 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted August 18, 2015 Share Posted August 18, 2015 Yeah make a new shaft. You could piss with that for hours and still have something that looks shit. If you DO insist on welding it up- grind down a mm so that your finished surface doesn't have hard spots where the weld and parent metal meet. 1 Quote Link to comment Share on other sites More sharing options...
evil_si Posted August 18, 2015 Share Posted August 18, 2015 Take it to MacLean metal spraying in onehunga Maclean Metal Spray 6 Miami Parade, 09-634 3151 Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted August 18, 2015 Share Posted August 18, 2015 building that up to size again with metal spraying is rediculous. You cant reliably add that much material back with metal spraying, it will be a super expensive piece of shit once youre done. +1 to machining a new shaft 1 Quote Link to comment Share on other sites More sharing options...
ta63-1uzze Posted August 18, 2015 Share Posted August 18, 2015 machine part welding? get it welded with heat treatable filler wire and get that shit treated afterwards so it wont wear out again . Quote Link to comment Share on other sites More sharing options...
Mickey Posted August 18, 2015 Share Posted August 18, 2015 Machine part welding would definitely be the place to go if you want something like that repaired whether that means welding and machining or just remaking the shaft altogether. They'd be able to advise you on the best option in regards to cost and longevity. Quote Link to comment Share on other sites More sharing options...
evil_si Posted August 19, 2015 Share Posted August 19, 2015 Just looked at original post on computer rather than phone, if you want to build up the sections at the end you'd be best to replace it never had a good experience with machine part welding was 6-7years ago thou, have had good results from metal repair systems in otahuhu Quote Link to comment Share on other sites More sharing options...
Muncie Posted August 20, 2015 Share Posted August 20, 2015 Just looked at original post on computer rather than phone, if you want to build up the sections at the end you'd be best to replace it never had a good experience with machine part welding was 6-7years ago thou, have had good results from metal repair systems in otahuhu Can vouch for them too their head welder demo'd his prowess by cutting a beer can in half rotating top half a turn then tigging back together. 1 Quote Link to comment Share on other sites More sharing options...
