  • Replies 55
The lazy axle are shockers for getting stuck off Rd ,mate had one on a isuzu he used to say it would get stuck on a slippery banana and have towed a few out,I don't know what suspension it is using if it has airbag im sure you could do some thing tricky
Axles are on airbags, traction improves and turning radius improves once lifted. Axle was fitted to lift load capacity to 25 tonnes
Oh wicked- Im really glad you have started posting this up Martin!  There certainly does seem to be a lot of love on oldschool for trucks/buses/cabins/shacks/containers- much more so than most would expect from what is mainly a car forum. I think many are seeing them all as a proper viable alternative to normal housing on cost basis alone! For us that was the primary reason but building ours was so fun (most of the time..) and suits us fine. Will you be selling up after building this and then travelling?
Hinos...a fine choice in truck I must say.. :-) You have so much load capacity and length to play with. Things like;  fitting an Argar to heat it all rather than just a small wood burner. Spa pool up on the roof.
I'm looking forward to more updates!
Alex
The interior layout of the build had sort of decided itself, top lofts front and rear, kitchen area forward, two opposing slide outs in the centre giving us a lounge and dining area, toilet & shower towards the rear to one side. Main entry at the rear, this led to the need for a rear deck to make entry easier.
A lot of time went into measuring and determining allowable overhangs not to mention impact on ground clearance and swing radius, in the end a dimension was decided on and the rear deck began.
No painting fairies in my world!
http://P1040380.jpg image upload no size limit
Cross members added to support decking material.
http://Looking_down_at_rear_deck.jpg image sharing sites
Here is how the rear ended up looking.
http://P1040393.jpg image upload no limit
Our next build will be a cabin to get towed up to our ridge top. I love seeing more builds like this! Need to persuade kk into building his housetrailer !
Slide outs were tackled next, the frames have been fabricated in the same manner although a lighter gauge of steel has been used. The slide outs oppose each other and increase the overall width to 4.5 metres when extended. When they are locked away there will be a 450 - 500 mm gap between them inside, I don't see this as a to much of a problem as the aim is to make them easy to release and extend.
http://20141018_102109.jpg windows 7 screenshot
This slide out will house a fixed 2 place dinette arrangement, the end of the table will lift up increasing capacity to 5.
http://20141018_102138.jpg how to do a screenshot on a pc
This slide out will house a 2 1/2 seater lounge suite, yet to be selected.
http://20141027_073836.jpg free photo upload
The frames are fitted with rubber rollers that will run over the hardwood flooring, the outer rollers are mounted on the bottom rail of the outer walls, these rollers will be of a much harder material than the inner rollers.
Support details, lock details and weather seals have yet to be developed. The junior supervisor doesn't seem overly concerned at this point.
The front roof was tackled next. The steel work was battened up, framework added and a ply wood roof installed over the top. The plywood was treated with MetalX (timber preservative) and then covered with a standard builders paper.
The edges of the plywood then had an aluminum angle fitted to provide a finish edge for the roofing material.
I chose asphalt shingles for the roof, they turned out to be easy to fit and quite rewarding once you had learnt not to waste shingles on starter lines! The other important component was the strategic use of Sika Bitumen based sealer.
I had become concerned that the height tolerance I had allowed was not enough so i took the unusual step of creating a flat section along the ridge line, this doubled my tolerance.
The flat certainly made the fitting of the ridge cap much easier.
Finished result looks quite pleasing..............so far no leaks!!
Shingles came from an Auckland supplier, 3 m2 per pack at around $63.00 per pack, that's roughly $20/m2.
I used a different shaped shingle for ridge flashings, each tile cut into 3.
Off cuts from the flashing shingle strips were used as starters.
These shingles are best applied when its really hot! the shingles relax into shape better, the bitumen glue lines on the underside of the tiles activate quicker and the things are way easier to cut.
Yes, in fact the supervision team consists of a senior fluff and a junior fluff, they both maintain an active interest in the project.........not!!
