Flash Posted November 8, 2014 Author Posted November 8, 2014 My V8 Transit is also using over 20L to 100kms at the moment, probably closer to 25! And that is with a Holley 350 2 barrel. What diff ratio do you have fitted, and what gearbox are you running? And carb choice makes a huge difference. The Edelbrock carbs are supposed to be very economical, as long as you don't go silly on sizing, I have a new Edelbrock 500 that I am going to fit to mine. And as already suggested, it's hard to beat a Quadrajet, with its staggered throttle sizes! I have no experience of the Quickfuel carbs, but a quick look around the forums suggest they are liked by a lot of people. Have you got it set up & jetted properly? That is pretty thirsty for a 2 barrel browndog. My mate is running a 302 with a 2 barrel Holley in his Bedford van and on a trip back from Kawhia last Sunday he averaged 12.8 litres per 100km. I drove right behind him so our speeds were similar and I ended up averaging just under 21 on the same trip. His van is running a C4 and a 3.0 diff ratio. Only difference is that he is running 15 inch rear wheels with a 50 profile tyre compared to my 14 inch 50 profiles. My van is running a TH350 and a 3.0 ratio diff. Revs are around 2700 at 100km/h. I had my Quickfuel professionally setup by a local V8 specialist (I won't mention any names, but they have a pretty good reputation). It wasn't a cheap exercise. I've done about 8,000km since I had the dyno setup done. Everyone I've spoken to blames the crap aerodynamics of the van for the high consumption but my mate's van proves that decent economy can still be achieved. Quote
dr.wylde Posted November 8, 2014 Posted November 8, 2014 My God This is cool! you sir, need a rochester quadrajet! easy enough to come by. set and forget cant recommend them enough! I have one on my 308 Statesman (OEM) Mind you my diff is a 2.74 ratio Quote
Flash Posted November 8, 2014 Author Posted November 8, 2014 My God This is cool! you sir, need a rochester quadrajet! easy enough to come by. set and forget cant recommend them enough! I have one on my 308 Statesman (OEM) Mind you my diff is a 2.74 ratio yep, they sure seem to be a popular choice. Quote
Threeonthetree Posted November 8, 2014 Posted November 8, 2014 Here's the underside of a Quadrajet: Their spreadbore design (as opposed to square bore where both the primary and secondary inlets are the same size) means that when properly set up, they can give excellent economy when cruising on part throttle yet flow very well when the secondaries are opened. 2 Quote
browndog Posted November 8, 2014 Posted November 8, 2014 That is pretty thirsty for a 2 barrel browndog. My mate is running a 302 with a 2 barrel Holley in his Bedford van and on a trip back from Kawhia last Sunday he averaged 12.8 litres per 100km. I drove right behind him so our speeds were similar and I ended up averaging just under 21 on the same trip. His van is running a C4 and a 3.0 diff ratio. Only difference is that he is running 15 inch rear wheels with a 50 profile tyre compared to my 14 inch 50 profiles. My van is running a TH350 and a 3.0 ratio diff. Revs are around 2700 at 100km/h. I had my Quickfuel professionally setup by a local V8 specialist (I won't mention any names, but they have a pretty good reputation). It wasn't a cheap exercise. I've done about 8,000km since I had the dyno setup done. Everyone I've spoken to blames the crap aerodynamics of the van for the high consumption but my mate's van proves that decent economy can still be achieved. yes it is very thirsty, mine has a 3.9 diff so pulling 3300 rpm@ 100 kph. I have a set of 3.5 diff gears to go in, plus a 4 spd overdrive auto which will drop the revs to 1960rpm @ 100kph. And I will fit the Edelbrock to it at the same time. Sub 15L/100km is what I am aiming for, I think it should be achievable, and your mates van pretty much proves that anyway! To make matters worse, my van has a small 45L fuel tank, so the range is abysmal at the moment! You could drop your rear axle ratio to 2.7, which would give 2300 rpm@100kph, but will make it a bit more sluggish off the line. As an aside, I also have a LDV 400 van, it is an ex police van, factory Rover V8, 5 spd, and weighs 2000kgs empty. 15-18L/100kms is fairly easy in this on a trip, and it is much bigger and heavier than the Transit. And diff ratio not ideal either, it has a 4.45, and with the 5 speed it is doing 2700 rpm@100kph, so about the same as yours. Yes the van aerodynamics are crap, but I have heard of plenty of examples of Bedfords and Transits that can achieve over 20mpg (14L/100km) with a V8 fitted, so I am certainly aiming to improve mine. Quote
j.e.d. Posted November 8, 2014 Posted November 8, 2014 Hey Flash, what'd set you back to get the van blasted? Cheers Quote
Flash Posted November 8, 2014 Author Posted November 8, 2014 Hey Flash, what'd set you back to get the van blasted? CheersJ.e.d it was $1400 plus GST. That was back in March 2012. Quote
Flash Posted November 8, 2014 Author Posted November 8, 2014 That Quadrajet looks the business. Where can I find one ? Quote
Flash Posted November 8, 2014 Author Posted November 8, 2014 Hey browndog, it sounds like we are both on the same mission. Would be good to compare findings. I'll keep you posted on my progress. You based in the big smoke ? Quote
browndog Posted November 9, 2014 Posted November 9, 2014 Hey browndog, it sounds like we are both on the same mission. Would be good to compare findings. I'll keep you posted on my progress. You based in the big smoke ? sounds good Yep I am in Glenfield. Quote
Flash Posted November 9, 2014 Author Posted November 9, 2014 Cool, do you come thru to the monthly burger nights? Would be good to catch up. By the way I invested $30 in an adapter plate and last night I chucked a spare Holley 350 2 barrel onto my van just for shits and giggles. I ran out of time so it was straight on with no adjustment and it sure smells like it is still running rich at idle. Earlier today we did a cruise out to Orewa and I gassed up when we got home. Worked out to 15.5 liters per 100km. I didn't really notice much reduction in performance either. 1 Quote
browndog Posted November 9, 2014 Posted November 9, 2014 I have been to one of the burger nights a couple of months ago. When are they again? Interesting about the 350 Holley. That's a very good gain in MPG! You know that you can trim the idle mixture on these quite easily? Just wind the idle screws fully in,(one each side of the metering block) then back them out until idle is smooth. Usually 1 1/2 - 2 turns is about right on these. Would be good to get mine to 15L:/100 kms. But I think the diff ratio is hurting mine at the moment. And all of my running has been around Auckland, I haven't really taken it on a good run yet. Quote
flyingbrick Posted November 9, 2014 Posted November 9, 2014 Wow...that's a heap of energy being spent on the bodywork....respect for getting it done right! Quote
Flash Posted November 9, 2014 Author Posted November 9, 2014 I have been to one of the burger nights a couple of months ago. When are they again? Interesting about the 350 Holley. That's a very good gain in MPG! You know that you can trim the idle mixture on these quite easily? Just wind the idle screws fully in,(one each side of the metering block) then back them out until idle is smooth. Usually 1 1/2 - 2 turns is about right on these. Would be good to get mine to 15L:/100 kms. But I think the diff ratio is hurting mine at the moment. And all of my running has been around Auckland, I haven't really taken it on a good run yet. I think the next burger night is on the 19th November. Would be good to catch up if you can make it. Stu my mate with the 302 in his Bedford should hopefully be there too. I'll play around with the idle mixtures and will let you know how it goes. Quote
Flash Posted November 9, 2014 Author Posted November 9, 2014 Wow...that's a heap of energy being spent on the bodywork....respect for getting it done right! Cheers for that. Quote
browndog Posted November 9, 2014 Posted November 9, 2014 I think the next burger night is on the 19th November. Would be good to catch up if you can make it. Stu my mate with the 302 in his Bedford should hopefully be there too. I'll play around with the idle mixtures and will let you know how it goes. okay cool, I will try to get there. Quote
flyingbrick Posted November 11, 2014 Posted November 11, 2014 Awesome build story! So the red van only donated gearbox and exhaust? Bahahhaha Quote
Flash Posted November 11, 2014 Author Posted November 11, 2014 Awesome build story! So the red van only donated gearbox and exhaust? Bahahhaha Also used the aluminium radiator, Ford 9 inch diff, disc brake front conversion, Momo steering wheel and boss and a few other minor bits. I flicked on the donor van and the overall cost was $300 for the parts I took. Not too bad and I got to use the donor van for 18 months while my van was off the road. 1 Quote
CUL8R Posted November 11, 2014 Posted November 11, 2014 Really rather enjoying the details and direction you're taking here, Looking forward to seeing the finished product.. Early fronts look so much better than the late model / "jumbo's"! Quote
