KP60 Circuit car tips and help
EFI_LC
  • Replies 78
Sweetness folks, cutting is no issue for me.
1. 60psi or there abouts, with a returnless fuel line. So you need an aftermarket FPR.
2. From factory they have a dual mass flywheel which is a big heavy shitsack (15+kg) but light aftermarket options available.
3. It's a tall and wide engine with a gearbox that doesnt fit the tunnel. So pretty much everything's a problem, for a starlet. A 4age/T50 will be about 5% of the ballache to get fitted and running. Beams starlet has been done before, I think there's a project on here or toyspeed. But not something I'd want to do!
4. Not sure.
Sweet, that gives me something to aim for then :)
The flywheel will give me something to change later at least and should help liven it up a bit.
I have no problem giving it a nip and tuck and I will trade a bit of extra weight and height for 200hp + 6-speed compared to extracting that much from a 4a or 4k. It has already had some mods as it was running a 12a at Ashburton Street meet which is my aim to have it ready for next year.
300hp stock?
I chose the Beams engine for several reasons, one being over 200hp stock N/A as I didn't want the additional heat of a turbo while sorting it out, the other was a 6 speed box, the cost was a factor at around $2k for both box and motor and the weight another.
I figured that 209hp with this in a Starlet should equal to a shit load of fun, I am not about what I should put in it but about what I am going to put in it and the fact it was a Toyota in a Toyota also seemed good.
Thanks though for all the suggestions and thanks for the link to the previous project.
K24s are certainly impressive.
http://www.k20a.org/forum/showthread.php?t=71489
They are the only motor I would look at if I was in the market for a na 4 banger.
It may suit you but it's not my idea and as for hp these Beams and countless other engines could be tuned way past that but again the idea of what I wanted is 200hp+ with 6 speed and RWD for $2k and just fit it and wire it, un-stressed and reliable running while i have do handling not spending my time building an engine.
Well thats the plan, leave the other stuff to young guys who have fat wallets or charge it up for kicks :)
Lol so the only option you'd ever consider, is the horrifically expensive one?
K series are great but Honda tax makes my wallet cry.
Then that x100 if wanting to RWD one.
Oh, is that all a K24 costs these days? Cool.
Either option costs a shit tonne more than $2k though... You need dry sump to have any chance of fitting a K24 in a starlet. Custom manifolds etc.
$10k minimum in bits I'd say.
Guy Lance in Oamaru is doing one, will be awesome when it's going. Spendy project though. Converted it to left hook partially because the exhaust runs down other side of the engine. and makes the steering column a pain.
Yea, you can ring up Strongs right now and buy a k24 out of a crv for that much, super legit.
You need to fit a dry sump to any track car, so that is hardly a consideration in terms of engine choice.
And yes the Initial buy in is the cheapest part of building a car, we all know that.
And the reason why I would only use a Honda is because you try getting 275hp out of a beams, I bet it takes a bit more than a ported head, cams, and manifolds.
back the truck up beave
on this occasion he is talking sense,  those honda motors really are actually "that good"  its going to be less stressed to do whatever output you want, probably newer? has better aftermarket support and more scope for upgrades. initial cost difference to beams is minor. and like he said if its a proper circuit car you should be dry sumping really.
if its a circuit car and you dont need a dry sump you aren't cornering hard enough surely?
That's not the point. He has already decided on a beams engine, and going by the fact he posted a picture of one, I would think that means he has purchased said engine. Therefore ranting on about how a different engine is a better option isn't very helpful is it?
Must be something in the Taupo water.
