yetchh Posted July 20, 2014 Share Posted July 20, 2014 Yeah so I have to cut my 121 rear stops down then refix them to the base plates, anyone had any luck doing this or did you go down another route? you can see one here, need to cut it down by about half.. Quote Link to comment Share on other sites More sharing options...
chees- Posted July 20, 2014 Share Posted July 20, 2014 cut the 'top' off and reshape with a grinder. 1 Quote Link to comment Share on other sites More sharing options...
Snoozin Posted July 20, 2014 Share Posted July 20, 2014 What he said, I've done this many times and it work's a treat. Quote Link to comment Share on other sites More sharing options...
yetchh Posted July 20, 2014 Author Share Posted July 20, 2014 How does it look tho? Kind of going for the 'factory' look.. want it to pass re-vinning. Quote Link to comment Share on other sites More sharing options...
chees- Posted July 20, 2014 Share Posted July 20, 2014 if you're careful with the grinder they'll look factory again, i went pretty hack job on mine and managed to get them ok, cert guy didn't notice. Quote Link to comment Share on other sites More sharing options...
yetchh Posted July 20, 2014 Author Share Posted July 20, 2014 Ok I'llgive it a go, have the grace of being 6 up.. what type of disc do you use? Quote Link to comment Share on other sites More sharing options...
kicker Posted July 20, 2014 Share Posted July 20, 2014 Not sure about the others but I used a twisted wire cup brush on my grinder, hacksaw to size then shape with grinder Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 20, 2014 Share Posted July 20, 2014 Not sure about the others but I used a twisted wire cup brush on my grinder, hacksaw to size then shape with grinder I have also used this method, works a treat Quote Link to comment Share on other sites More sharing options...
danger Posted July 20, 2014 Share Posted July 20, 2014 Just cut them and sand to shape. Run over them with a gas torch afterwards if it tickles your fancy. Alternatively, buy shorter ones from BNT Quote Link to comment Share on other sites More sharing options...
danger Posted July 20, 2014 Share Posted July 20, 2014 Ok I'llgive it a go, have the grace of being 6 up.. what type of disc do you use? I use a cutting disc to cut them and a linishing disc to shape them. Remember to open up your shed as you'll smoke it out Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 20, 2014 Share Posted July 20, 2014 i went with - cut short with hack/bandsaw, stanley knife to shape, linisher/upsidedown belt sander to finish. coarser the belt the better Quote Link to comment Share on other sites More sharing options...
yetchh Posted July 21, 2014 Author Share Posted July 21, 2014 Does it not look a bit burred? Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 21, 2014 Share Posted July 21, 2014 It will be fine. Paint it with underseal if you are worried. Quote Link to comment Share on other sites More sharing options...
yetchh Posted July 21, 2014 Author Share Posted July 21, 2014 Haha, yeah I'll give it a crack.. Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 21, 2014 Share Posted July 21, 2014 nah, finish is directly proportional to time spent and care taken. paint bumpstops? jeez beaver! 1 Quote Link to comment Share on other sites More sharing options...
Beaver Posted July 21, 2014 Share Posted July 21, 2014 haha the entire underside of the 120y is covered in the shit (bump stops, cross members, lowering blocks etc). it means its factory you know. 4 Quote Link to comment Share on other sites More sharing options...
yetchh Posted July 22, 2014 Author Share Posted July 22, 2014 10mins worth of work, could still do with a bit of shaping but very easy to do, just cut the top off with a 1mm blade then twisted wire brush on grinder then flap disc.. couldn't be easier cheers fellaz.. just need to add custom dirt.. 5 Quote Link to comment Share on other sites More sharing options...
Bling Posted July 22, 2014 Share Posted July 22, 2014 That's a tidy job, nice one! Yeah a nice clay dusting will have it matching nicely. Quote Link to comment Share on other sites More sharing options...
downtrail Posted July 23, 2014 Share Posted July 23, 2014 Trick used to be underseal car then whilst still takey go for a hoon on a gravel road lol 10mins worth of work, could still do with a bit of shaping but very easy to do, just cut the top off with a 1mm blade then twisted wire brush on grinder then flap disc.. couldn't be easier cheers fellaz.. just need to add custom dirt.. Quote Link to comment Share on other sites More sharing options...
Spooch Posted July 25, 2014 Share Posted July 25, 2014 Yea my fix to pass wof on leaky shocks was to clean then throw dirt upon item. Old dirt throw works every time mate Quote Link to comment Share on other sites More sharing options...
