Chris.QCR
Chris.QCRs 1980 Harley Davidson Sportster XLH1000
Another job done. Number plate mounted off a old drag pipe exhaust mount.
Going to re do the rear Indicator mounts and have them each side of the taillight instead of just under the seat
Will work on that this weekend.
Got some more Harley pipes on thier way which should be enough bits to get these Cocktail shakers connected to the motor.
Quite keen to see how your pipes mate up to your motor @Lord Gruntfuttock. This slide the pipe over the exhaust port and clamp idea is shit
Share this post
Link to post
16 minutes ago, Aubs said:
I love long forks
Got some longer forks lined up for it. Stock Harley Springer to the left for scale. Havent had final welding so I cam tweal the height a bit. Will run the springer with a drum 21 " front
Share this post
Link to post
Stripped down to get some parts powdercoated.
Then got fuel fitting to weld to tank and plumb up with new fuel filter.
Then fit a couple plugs to the loom.
Then final assembly with lots and lots of Nordlock washers & Loctite.
Should Coincide nicely with this bike going classic on Jan 1st 2020 and I can actually afford to register it
Share this post
Link to post
Bikes looking sweet, and the display theme was a good idea.
But,
Are you trying to tell us something? A few lyrics from the lumber jack song,
 "I cut down trees, I skip and jump
I like to press wild flowers
I put on women's clothing and hang around in bars
I'm a lumberjack and I'm OK
I sleep all night and I work all day
I cut down trees, I wear high heels Suspendies and a bra
I wish I'd been a girlie, just like my dear Papa"
  • Haha 2
Share this post
Link to post
