I was meaning on the diff side not the chassis, but i get the point/not easy.
And well if you do that you cant go for the untubbed record at the drags then either!
  • Replies 117
Im going to head into garage again after dinner and have a look.. gotta tidy up first tho! Fail.
Yes yes to drawing of brackets.
G
Nah got shed clean and then failed with diff as I have a slight issue.... only have 4x axle stands and they already under car holding it up.
Need another set so I can place diff under car centred and start playing/measuring. Might buy two tomorrow if I can get away from the desk.
Gaz
Yes. I wold like to know about blasting cars as I will have to do my coupe in the not too distant future...
Let me know when you do, will put you on to some of the better blasters in Northland, we supply most of them.
Car being dustless blasted so panels ain't warped. Using recycled glass or garnet? as media and water plus inhibitor. dont think too many places in nz doing process yet, us its big.
You're hammering through this project gaz!
Also, where are you getting panel and paint done?
What were you quoted for panel and paint? How much was the blasting too? (you can pm me if you don't want to post on thread)
Seems heaps cats want an idea on price.
Lets say:
To strip a whole car back to bare steel (including underneath) using dustless wet blasting & then to epoxy prime is about $2500.
Then ya panel man price would be dependant on the rust/dents but maybe say $1500
Then paint would depend on what product you use but lets say another $1-1500
Ill hit him up Chris, havnt talked to him since he took the car though.
Gaz
Ok, here's mine which looks the same. It's supposed to be an old (i.e. '70s) 13b but i can't really tell except that the "Mazda" logo on the housings is the old style.
Measurements are taken from the flange surface on the seal that mates against the corresponding surface around the dipstick hole, to the nearest mm and as best as i could with a tape measure.
From seal flange to "F" end of crosshatched area = 234mm
From seal flange to "L" end of crosshatched area = 265mm
From seal flange to end of dipstick = 274mm
Fukn ledgend! I was just looking through service manual to figure out how much to pu in... now I dont need to.
Cheers bro
Gaz
