flyingbrick Posted November 27, 2013 Share Posted November 27, 2013 how cool is this. blown up with water blaster. 2 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 28, 2013 Author Share Posted November 28, 2013 That's a two stroke zorst by the way. there's heaps on YouTube. If you want to scare yourself look up explosive hydroforming Quote Link to comment Share on other sites More sharing options...
Yowzer Posted November 28, 2013 Share Posted November 28, 2013 How do you release the pressure once it's full? Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted November 28, 2013 Share Posted November 28, 2013 You could have an exhaust teed into the feed line. Just a ball valve of something would be sweet I imagine. Quote Link to comment Share on other sites More sharing options...
Testament Posted November 28, 2013 Share Posted November 28, 2013 its pretty cool but you need to understand whats going on and the possible risks etc. Â in that case he is starting with two flat sheets so its not too bad but any air in the vessel being formed is potentially dangerous 1 Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 28, 2013 Share Posted November 28, 2013 If you watched the other videos then he has a tap and bleeds all the air out. It is pretty harmless, you are only putting a few litres of water in there so it really isn't a big deal. Â Â Also it would probably spring a leak before it exploded anyway. 1 Quote Link to comment Share on other sites More sharing options...
V8Pete Posted November 28, 2013 Share Posted November 28, 2013 its pretty cool but you need to understand whats going on and the possible risks etc. Â in that case he is starting with two flat sheets so its not too bad but any air in the vessel being formed is potentially dangerous Should whack a sweet high point vent in it Quote Link to comment Share on other sites More sharing options...
JoKer Posted November 28, 2013 Share Posted November 28, 2013 Mythbusters did it making a Torpedo  http://dsc.discovery.com/tv-shows/mythbusters/videos/torpedo-tastic-aftershow-1.htm  thought that looked fun to try at the time  Discussion on the HAMB about the same show/technique  www.jalopyjournal.com/forum/showthread.php?t=586952 Quote Link to comment Share on other sites More sharing options...
Testament Posted November 28, 2013 Share Posted November 28, 2013 If you watched the other videos then he has a tap and bleeds all the air out. It is pretty harmless, you are only putting a few litres of water in there so it really isn't a big deal. Also it would probably spring a leak before it exploded anyway.   some people don't have all day to sit on youtube dave#4576346  yes it is likely it would spring a leak first - but its completely possible it could have a violent failure. understand what you are doing and the risks you may be taking, it's your life so be responsible for it and own the risk because you can't count on anyone else to.  if it were me I would put in the contract for v8pete to install a HPV in an appropriate location and would follow good filling/venting procedures. then I would stand as far away as practical while the pump was running. 2 Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 28, 2013 Share Posted November 28, 2013 Good chob Safety Tom! Quote Link to comment Share on other sites More sharing options...
slacker.cam Posted November 29, 2013 Share Posted November 29, 2013 understand what you are doing and the risks you may be taking, it's your life so be responsible for it and own the risk because you can't count on anyone else to. Â Did you start condoning this philosophy before or after you tried to grind your arm off with a guardless grinder? Trolololol. 2 Quote Link to comment Share on other sites More sharing options...
V8Pete Posted November 29, 2013 Share Posted November 29, 2013 Also, waterblasters are amazing. I bet if Lloyd had anything to do with hydrotesting your steam factory he would've used a Kerrick waterblaster. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted November 29, 2013 Share Posted November 29, 2013 hey man we heard you got to level 9.9 yesterday, fingersinthedangerzonecam Quote Link to comment Share on other sites More sharing options...
V8Pete Posted November 29, 2013 Share Posted November 29, 2013 If you watched the other videos then he has a tap and bleeds all the air out. It is pretty harmless, you are only putting a few litres of water in there so it really isn't a big deal. Â Â Also it would probably spring a leak before it exploded anyway. That comparison between pneumatic and hydraulic was lol. 1 Quote Link to comment Share on other sites More sharing options...
Testament Posted November 29, 2013 Share Posted November 29, 2013 Also, waterblasters are amazing. I bet if Lloyd had anything to do with hydrotesting your steam factory he would've used a Kerrick waterblaster. nah he was in charge of the fire system Quote Link to comment Share on other sites More sharing options...
Testament Posted November 29, 2013 Share Posted November 29, 2013 its still not finished properly yet Quote Link to comment Share on other sites More sharing options...
Testament Posted November 29, 2013 Share Posted November 29, 2013 Did you start condoning this philosophy before or after you tried to grind your arm off with a guardless grinder? Trolololol. hey cam I tried very hard to find the guard beforehand but it could not be found at the time. I grinded my arm and not my face. I was very concious of critical items being out of the line of fire. I also didnt expect my arm/wrist to bend so much to allow the grinder to go around that far. and still I turned the power off on the grinder in 0.0004 seconds. but yeah I knew I should have used the hacksaw to cut the last bit before I did it. so I am an idiot. Quote Link to comment Share on other sites More sharing options...
yetchh Posted November 29, 2013 Share Posted November 29, 2013 some people don't have all day to sit on youtube dave#4576346  yes it is likely it would spring a leak first - but its completely possible it could have a violent failure. understand what you are doing and the risks you may be taking, it's your life so be responsible for it and own the risk because you can't count on anyone else to.  if it were me I would put in the contract for v8pete to install a HPV in an appropriate location and would follow good filling/venting procedures. then I would stand as far away as practical while the pump was running.   You mean like these guys?  Quote Link to comment Share on other sites More sharing options...
Testament Posted November 29, 2013 Share Posted November 29, 2013 yeah that was the one other one I watched and though fuck that. Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted November 29, 2013 Author Share Posted November 29, 2013 You want to see cringe worthy fabrication watch this. No glasses or other safety gear and he puts his hands so close to the sharp rotating material. Quote Link to comment Share on other sites More sharing options...
