oldrx Posted March 10, 2012 Share Posted March 10, 2012 I took the back seats out of the mazda the other week to run a new fuel pump wire, and discovered a bit of surface rust which i'm cleaning up at the moment while doing that i saw there is a bit of surface rust inside the framing for the seat and other cunty areas that i would have to drill out the spot welds and practically take the car apart to get to. Plus im sure up in the sills etc there must be a bit of surface rust. In a few years i want to repait so maybe i will acid dip, not sure but until then i want to stop any rust getting worse. Has anyone found any good aerosol rust converters that are good for this kinda stuff? Theres this but its not a rust converter just a fish oil type product http://www.permanentpaintedcoatings.co. ... e_Oil.aspx And this but you need to top coat it which isnt really practical either http://www.spraystore.co.nz/brunox-rust ... -1424.html Any ideas? Quote Link to comment Share on other sites More sharing options...
morkster Posted March 10, 2012 Share Posted March 10, 2012 tergo rust killer is good - i pour some into a spray bottle and use it like that Quote Link to comment Share on other sites More sharing options...
oldrx Posted March 10, 2012 Author Share Posted March 10, 2012 Im wondering about just firing some Phosphoric acid at it Quote Link to comment Share on other sites More sharing options...
JasonK Posted March 10, 2012 Share Posted March 10, 2012 I'd spray some brunox on it, its pretty good shit and comes in a can or in a container for brushing on. Quote Link to comment Share on other sites More sharing options...
oldrx Posted March 10, 2012 Author Share Posted March 10, 2012 Dont you have to overcoat that shit though? Quote Link to comment Share on other sites More sharing options...
nick_m Posted March 10, 2012 Share Posted March 10, 2012 cut your way in weld your way out. Seriously though, Dont use acid, you'll never get it out of the seams and it'll just rust them out, best bet is probably one on the rust converters mentioned above and then get as much of something to seal it up in the as possible, like an epoxy primer or a wax or something. Also those "odourless" Fish oils will make you car smell like fish for atleast a couple of years. They arent that odourless, atleast it did with the one my mates used in his 4wd Like you said you can only do so much without taking the car apart so just do your best. Its better than nothing Quote Link to comment Share on other sites More sharing options...
JoKer Posted March 10, 2012 Share Posted March 10, 2012 ^^ yea was about to say nothing is inaccessible with a grinder Quote Link to comment Share on other sites More sharing options...
Bling Posted March 10, 2012 Share Posted March 10, 2012 Not saying this is a good idea, but i've considered drilling ~10mm holes in the floor above chassis rails and spraying in some sort of protection. If that's not even possible then i'm not sure. Quote Link to comment Share on other sites More sharing options...
Spencer Posted March 10, 2012 Share Posted March 10, 2012 Its one of those things, without pulling shit apart you really cant do it properly, but usually that's a seemingly never ending process! I'm still on the lookout for a decent product I can put down my body deadener gun and into the cars crevices that has some rust kill abilities and doesn't need a top coat, I figure its all i can unless the car was dipped (that's a whole other can of worms) Quote Link to comment Share on other sites More sharing options...
Evan Posted March 11, 2012 Share Posted March 11, 2012 ive had this stuff http://www.versatileproducts.co.nz/shop ... +-+1L.html recommended to me by the guy at Autolink in hamilton. Havent tried it personally however. also seen it for sale at Bunnings. Quote Link to comment Share on other sites More sharing options...
oldrx Posted March 11, 2012 Author Share Posted March 11, 2012 Its one of those things, without pulling shit apart you really cant do it properly, but usually that's a seemingly never ending process! I'm still on the lookout for a decent product I can put down my body deadener gun and into the cars crevices that has some rust kill abilities and doesn't need a top coat, I figure its all i can unless the car was dipped (that's a whole other can of worms) You just know that 10c coin sized bit of surface rust is going to turn into a month long goose chase all over the car. That shit has a way of crawling around under paint. I think in the end you either pull the entire fucker apart and risk never getting around/affording to put it back together again or leave it/spray some shit down there and convince yourself its going to be ok. Quote Link to comment Share on other sites More sharing options...
nick_m Posted March 12, 2012 Share Posted March 12, 2012 Yeah that ^ Driving a car is way more fun than fixing a car haha Quote Link to comment Share on other sites More sharing options...
Sorensin Posted March 12, 2012 Share Posted March 12, 2012 POR15 - sticks really well if theres a bit of rust in it- if its really light rust over fill it with cavity wax- if areas suit drill drain holes Quote Link to comment Share on other sites More sharing options...
Testament Posted March 12, 2012 Share Posted March 12, 2012 I'd spray some brunox on it, its pretty good shit and comes in a can or in a container for brushing on. yeah brunox works pretty well, was recommended by my panelbeater fish oil/lanolin oil every 6 months works pretty well, and the comment about drilling drain holes in strategic locations is a good one too. Quote Link to comment Share on other sites More sharing options...
