Brennan's, ke70 Corolla, 3sge Beams powered.
Brennan
The cams where doing some funny things on the first dyno too. but that may have been related to one of the many other problems.
Guy on altezza forum had a similar cam rattle and eventually found that it was because of low oil pressure, caused by the sump being bashed into the pickup point. Mine is a little dented next to the drain bung.
Im also using 5w40 penrite oil, so will go to a 5w30 castrol synthetic and see it that helps.
Not really so keen on pulling the cambelt off with what ever else needs to be removed to access the filter.
  • Replies 322
Hey. They are the 195/45/14 toyo's
14 inch tyres are going to be a bit of a nightmare in the decent future I feel. As from what I can tell most companies including toyo have stopped making low profile 14's.
badass! choice to see you're still having fun mucking round with stuff!
if you're after a flash harry flywheel i might know a guy with a surplus trd lightweight chromoly one from an altezza (he replaced it when he did a clutch and thought he had a dual mass, so he bought a single mass exedy heavy duty kit and used the flywheel that came with that and instantly regretted it. reckons the trd one makes them heaps peppier).
I shal enquire
edit: he wants $120, is in palmy and is going to make sure he definitely still has it and will weigh it for ya. will keep you posted.
  • 3 months later...
I remember one instance when you were behind me after leaving the pub yesterday. You were about 30metres back and we were sitting at about 80-90kph.
I saw a bit of a lump in the road which I thought 'shit, some of the lower jokers are gonna clip that'
a second later I heard a pretty huge geesh coming from your car. must be a few scrapes on the underneath of you slammed jokers from that road!
I think sparkle has a couple of shiny bits underneath the BMW now too!
  • 6 months later...
I went to the Palmy monthly meet yesterday and this little corolla caught my eye.
Everything is spot on.
I've just read the build thread from the beginning. I didn't realise how much work you have done to it.
Great job man. Well done.
  • 7 months later...
Very nice car mate, any chance you could do a brief summary of parts needed for the swap as ive just picked up a beams setup and am looking into the exact same thing myself, looks like a blast to drive!
Cheers, yes is pretty crazy to drive.
Not a lot needed really, apart form the obvious engine, gearbox, driveshaft.
Link g4
Fuel pressure regulator
radiator with the in/outlet on the corect side. (i was looking at a alloy ae86 one from china not long ago that was correct(may have been for a usdm ae86))
w5# series speedo cable to fit in the j160 and replace the electronic one (reads about 10% out on mine)
