Fliboi
Fliboi's 1971 Toyota Corona
165 posts in this topic
I think I saw you cruising in this on the coastal highway, north of Wellington, at about 11am today. I was cycling north at the time.
I assume you weren't the pilot vehicle for the gaggle of Highway 61 chaps that were a minute behind you on their hogs?!
Share this post
Link to post
Yep that would have been me, just smashed out a Blenheim to Auckland trip since I'm now posted to whenuapai. Wasn't a pilot vehicle for those bikers though haha.
I'll do more of a write up on my trip when I get my Internet set up, but that's the furtherest I've ever driven it! And I had so much gear in it I was 25mm off the ground. My exhaust is toast
1 person likes this
Share this post
Link to post
Yo dude. Just pm you about a garage. Im at base as well. If need be you can you use mine
Share this post
Link to post
Yeah dude sounds like it could be a plan! Just need to track down a welder now haha, moving city's sucks!
Don't suppose you drive that sweet Toyota crown I saw? Though there are quite a few nice old cars around here
Share this post
Link to post
Theres another fella there too from os did some work on his megasquirt. Told me they cant cook in the kitchen due to fire hazard haha still makes me laugh.
Share this post
Link to post
Yeah that drives me insane, it's pretty much a one fuckwit ruins it for everyone sorta deal.
Share this post
Link to post
Looks like you silicon'd the badges back on, or at least one of them?
Share this post
Link to post
The two gaurd badges are on with factory clips. The boot badge is missing most of the mounting posts and I tried a slightly adhesive silicon because I don't want to damage the paint.
But its not worked so I'll be trying something else
Share this post
Link to post
Get some double sided trim tape, adhere the sticky side to the back in a couple of strips then trim off around the letters, pull the plastic backing off the stickier side and slap that bitch on the bootlid. Just make sure you're square first time around.
Share this post
Link to post
Of course! Will do just that
Share this post
Link to post
Some aircraft engineer you are. Your screw heads aren't even aligned. :P
Share this post
Link to post
sometimes when we replace a screw we don't even put a black one back in  :pale:
ironically enough the gauge panel was made from some left over 2024 aircraft skin alloy  8) but the alclad layer was all fucked up so essentially worthless
Share this post
Link to post
ps - now youve mentioned the screw heads. im not going to be able to unsee it and ill have to fix it lol  :doubt:
Share this post
Link to post
How solidly is your engine mounted? Does that whole unit not flex under acceleration?
Share this post
Link to post
i have had this thought, and the honest answer is im not sure how its going to affect it, if at all. it doesnt seem to be too an issue at idle. and im not far off having the ecu in the car, at which point i can go for a drive with the laptop looking at the tps signal and make a decision.
but if it does present a problem, it will require a few more major parts to be redesigned so ill see how this goes.
Share this post
Link to post
as a quick follow up, when the engine is at it most shaky on warm up, at worst i get a 3% fluctuation of TPS signal. i dont think this will be enough to trigger a timing change, and even if it did it would only be a degree or so.
pretty sure it wont be that shaky once running proper timing control  anyway.
Share this post
Link to post
Might be an opportune time to consider switching to EFI perhaps? With the megasquirt already in action all of the hard work is done, just need to sort out fuel system and redo the manifold really. Could probably pick up some 4AGE ITBs pretty cheap
Share this post
Link to post
slightly tempted, though the entire idea was to retain carb induction. because i really like carbs. despite the fact i could probably get better results with fuel injection.
will consider though
, depends on how much its going to cost for the replacement parts or a new set of carbs. and to think, with the corona finished i was so looking forward into finishing the cycle car, or modifying the z31 for some track day fun haha.
1 person likes this
Share this post
Link to post
Definitely go efi, you will never look back. Just make some slide throttles that suit your manifold and call it good. Also get rid of the points haha
1 person likes this
Share this post
Link to post
my car sounds the same if not better with jetski throttle bodies and change to a trigger wheel, the dizzy solution is always a half assed one
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
