zep Posted May 25, 2011 Share Posted May 25, 2011 Hey guys, The ladder bar which secures the diff in my car to the chassis is fully rose jointed, 2 on the diff and 1 on the chassis mount/x-member. The diff has started to get real clunky and it's obvious movement in the mounting components. I haven't yet checked to make sure everything is nice and tight but I'm wondering how long these rose joints should last for and whether or not they warrant replacing? I'd say they've been on there for about 4 years now. Thrashing, etc. Brad, was it you I was talking to about this? Someone said that rose joints don't last that long... Chuuurs Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 25, 2011 Share Posted May 25, 2011 Yea man check them out, the life you get out of them depends on there use. Under a road car with dirt and moisture they can fuck out pretty quick, there are more expensive teflon lined ones that will last longer. Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted May 25, 2011 Share Posted May 25, 2011 seal the new ones with some old innertube and zip ties Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 25, 2011 Share Posted May 25, 2011 ^ haha cant argue with that! Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 25, 2011 Share Posted May 25, 2011 I agree!, that is a sterling idea. But yeah, I would expect some movement out of them by now Can also get ones with grease nipples, which might work better for long life, if you grease them often enough Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 25, 2011 Share Posted May 25, 2011 The proper teflon lined ones can be expensive, but there is two places in Auckland (cant remember the names sorry) that do a lot of american motorsport stuff, they sell good quality ones pretty cheap, say $30.00ea rather than $200.00ea. And they will last a shit load longer if you can keep then clean and dry. Quote Link to comment Share on other sites More sharing options...
zep Posted May 25, 2011 Author Share Posted May 25, 2011 seal the new ones with some old innertube and zip ties Can you expand on this? Do you mean just wrap them? Quote Link to comment Share on other sites More sharing options...
Steelies Posted May 25, 2011 Share Posted May 25, 2011 am i correct in thinking the fact that it's a ladder bar and not 4-link means the ladders and joints take up a lot of the roll force that a 4-link would otherwise allow? so increased wear etc? Quote Link to comment Share on other sites More sharing options...
zep Posted May 25, 2011 Author Share Posted May 25, 2011 Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted May 25, 2011 Share Posted May 25, 2011 seal the new ones with some old innertube and zip ties Can you expand on this? Do you mean just wrap them? yup Quote Link to comment Share on other sites More sharing options...
zep Posted May 25, 2011 Author Share Posted May 25, 2011 Sounds like a good plan. Now to find some new ones for not too much Quote Link to comment Share on other sites More sharing options...
mikuni Posted May 25, 2011 Share Posted May 25, 2011 Sounds like a good plan. Now to find some new ones for not too much If you find some decent quality ones like nzdamae86 mentioned above for cheap can you flick me the details. I'm going to be making up some lower arms for my racecar soon and getting onto some cheap rosejoints will be awesome. Just need to figure out what diameter I need. If you could also see if they supply pillow ball/spherical bearing mounts and a price on those. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 26, 2011 Share Posted May 26, 2011 nzdamae86 I see what you did there. I priced some up for a mate not so long ago for a hard cone 4x4 truck, i'll ask him if he can remember where I told him to go get them. Quote Link to comment Share on other sites More sharing options...
Steelies Posted May 26, 2011 Share Posted May 26, 2011 ah, gotcha. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted May 26, 2011 Share Posted May 26, 2011 also keen for info on rose joints for cheap Not sta parts or something was it? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted May 26, 2011 Share Posted May 26, 2011 Cardwells? Etchells? Segedins? Quote Link to comment Share on other sites More sharing options...
zep Posted May 26, 2011 Author Share Posted May 26, 2011 I've sent an email to the Bolt Shop up here. Will see what they say. Will check out Auckland Engineering Supplies on the weekend perhaps. Quote Link to comment Share on other sites More sharing options...
Roman Posted May 26, 2011 Share Posted May 26, 2011 Say you're from a race car, wear out quickly - rose joint life? P.S. When going through its travel, the end of one or more of your suspension arms effectively needs to get slightly shorter or longer, and this is change in length is normally allowed for by the rubber bushes. When you rosejoint everything, it forces all of the arms stay the exact same length, so stuff breaks instead when the suspension goes through its travel. (diff mounts and chassis mounts) Think about what happens when a 4 link suspension needs to allow for body roll... I'm pretty sure a top left and a bottom right suspension arm (or vice versa) need to increase or decrease in length slightly to allow this to happen. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 26, 2011 Share Posted May 26, 2011 One problem with pricing them through industrial places is they will (or should) price top shelf ones for automotive/aerospace usage, the only ones I could get through the bearing company I used to work for that would be safe to use/last a while were Fluro brand, and they are farking pricey, like $2-$300 each for a 16/20mm one. The ones I found that were fairly cheap, were made for motorsport, so met all the standards and shit. One of the places was Cardwells/Etchells I think, and the other was "something" motorsports? Will get a hold of my mate and find out soon. Quote Link to comment Share on other sites More sharing options...
JoKer Posted May 26, 2011 Share Posted May 26, 2011 bored :/ Quote Link to comment Share on other sites More sharing options...
