drtdvl Posted January 23, 2011 Share Posted January 23, 2011 Photos: Basic history: It started life as a white 1.6 gti and was used as a press-car (i've got the original NZ Car mag where it was on the cover being thrown around a gravel quarry.) In 2002 the pervious owner - Mark Herbert -built the car for the 2002 Dunlop NZ Targa, and unfortunately didn't finish the race due to an accident. Mark repaired the car and then it's sat in his workshop waiting for the finishing touches to be done since then. In 2008 went to see Mark to price up a rollcage for the 306, after 30 min of looking at the rollcage in the 205 to show me was he would do - i was sold - nice rollcage it was going to be... Mark then as i was walking out the door asked if i would like to buy the 205. I took 1 day for me to confirm that i could purchase the car - re: The GF approving that i spent the money on buying the car instead of a trip to the states, which as you can tell by reading this it was... The car will be used for tarmac events until i can afford the undercar protection and gravel suspension - so i'm figuring a few years off... (note: 2 yrs later i'm still not able to afford it... hehe) Engine: Oil Cooler = 11 Row external (i think it's 11 row) Mocal Engine = 405 MI16 4WD XU9J4 ECU = 405 MI16 4WD XU9J4 + Peter T Chip Engine Mounts: Customised Factory Top mount, Aftermarket Uprated Lower Mount, factory gearbox mount Sump = Customized Sump (Windage Tray, Increased Volume, Modified front) Fuel Lines = moved into cabin, all braided lines Oil Breather System = Custom 6-Bar PTS Oil Pump Spring Custom Heat Shield Washer bottle = 309 rear bottle Spec: Dyno’ed at 128hp at the wheel at 7500rpm (rev limit) Suspension: Rear: Cut down 306 S16 24mm anti-roll bar Rebuilt rear beam. Solid BakerBM mounts (group a) Spax Adjustable shocks Factory 1.9 GTI Torsion Bars Assuming 205 trailing arms Front: Bilstien Adjustable Coilovers (unknown spring/spring rate - est 200/250lbs) Adjustable Camber / Caster Plates 306 S16 Hubs with stud conversion Exhaust: Custom 2.5 inch system, painted with Black High Temp paint Gearbox / Drivetrain: 306 S16 driveshaft – gear box input end 405 CV’s 205 middle and hub driveshaft ends 306 S16 BE3 (same ratios as MI16) Kevlar Clutch Quaife automatic torque biasing helical gear LSD Upgraded linkages Custom Quickshifter Phosphor Bronze bushes Brakes: Front: Peugeot 307 XSP 283mm Disc / Calipers (rebuilt) Peugeot 406 23.8mm Master Cylinder Braided Lines Middle: Custom lines Wilwood Adjustable Bias Valve Hydraulic Handbrake Rear: 1.6 GTI front calipers using standard rear disc (converted from drum) Custom braided lines with banjo fittings caliper end Body: Painted Unknown Silver Color Satin Black painted trim, door handles, wing mirrors, slam panel, skuttle plate, gti badges E30 Pre-Facelift lower lip – modified to fit 206 GTI rear wing – modified to fit Sump Guard Clear front indicators 405 arms wiper and 306 blades (larger sweep area) 205 “Automatic” Bonnet Spotlights cut out of Bumper Rear 1/4 windows = Lexan Sideskirts have had jack mounts fabricated into them 3M High Temp Foil Tape along trans-tunnel 88 GTI wing mirrors (smoother and smaller then later gti mirrors) Interior: Battery behind co-driver’s seat Water Temp, Oil Temp, Oil Pressure gauges Electric Kill Switch Interior Panels replaced with Carbon Fibre Panels Chrome-Molly Roll Cage Interior Completely stripped bar Roof Liner Dash modified to fit rollcage Seats = Racetech 4009w (D) & Racetech 4000 (P) Belts = Racetech (TRS) 3inch 6-point Steering Wheel = Momo Race Flooring = Checker Plate, sound deadening removed Terraphone Professional Amplifier + 2 x touring head sets Custom Extended Steering Wheel Shaft Wheels: 4 x 15inch ROH Astrons 4 x 306 S16 rims 4 x 405 MI16 2 x 205 GTI “speedlines” Future Plans: 22mm Torsion Bars, 25mm Anti-Roll Bar Rebuild front bilstiens, new rear bilstiens, new front springs 1.9 GTI Hubs, 309 control arms, 309 rod ends, Quaife Quick Steering Rack, 309 Middle driveshaft components Seam Welded front subframe New Engine mounts Carbone Loraine RC6 Pads Aftermarket ECU, Quad Throttles, Upgraded Cams Custom Gearbox – S16/MI16 1st, 2nd, Final Drive – 1.6 GTI 3rd, 4th, 5th Quote Link to comment Share on other sites More sharing options...
drtdvl Posted June 13, 2011 Author Share Posted June 13, 2011 Had a Motorkhana on Sunday - 5th out of 55, and 2nd in class. New wheels on the car so heres the update... Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 13, 2011 Share Posted June 13, 2011 choice bruv. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 13, 2011 Share Posted June 13, 2011 LIKE, Very cool, cage looks like a good E! Quote Link to comment Share on other sites More sharing options...
rebel county Posted June 13, 2011 Share Posted June 13, 2011 savage 205, would love one! Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted June 14, 2011 Share Posted June 14, 2011 may i ask why its making all its power on redline? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 14, 2011 Share Posted June 14, 2011 because xu9j4 engines are weird. can't wait for my piece to be finally going. need cage and also to do skids with you Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 14, 2011 Share Posted June 14, 2011 Mi16 should rev more than 7500 shouldn't it? Quote Link to comment Share on other sites More sharing options...
drtdvl Posted June 14, 2011 Author Share Posted June 14, 2011 may i ask why its making all its power on redline? larger exhaust, shortened intake manifold, and unknown engine work would be my assumptions but ya no idea? We extended the rev limit from 7200 to 7500 and it's just starting to flatten off now. Red = pre-chip, blue = post chip... runs done back to back ignore the rpm's they didn't match up for some reason. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 15, 2011 Share Posted June 15, 2011 Hah, he needs to click the dyno sheet so it goes to 7500... Dyno dynamics is lol like that (you could make it look like the car is making 50hp at 9krpm and 128hp at 12 if you wanted to. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted June 15, 2011 Author Share Posted June 15, 2011 haha kool... it's a lot lower reading than torque performance where it was doing 138hp @ wheels pre chip Quote Link to comment Share on other sites More sharing options...
westy Posted June 15, 2011 Share Posted June 15, 2011 Ha, it's Gavin, he gives no fuck for the numbers ya pull but is a top notch tuner. Top car Heath, paint it Renault yellow. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted June 15, 2011 Share Posted June 15, 2011 My tuner is much the same. Lucky I'm no dyno queen. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted June 15, 2011 Author Share Posted June 15, 2011 i do want it renault liquid yellow! Quote Link to comment Share on other sites More sharing options...
drtdvl Posted June 25, 2011 Author Share Posted June 25, 2011 couple more pro shots from the day. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted August 1, 2011 Author Share Posted August 1, 2011 Quote Link to comment Share on other sites More sharing options...
drtdvl Posted August 10, 2011 Author Share Posted August 10, 2011 Installed the new Carbone Lorraine RC6 pads are FRICKEN AMAZING!... 100% Sintered metal pad, No bedding in required, and work amazingly well when cold. Pedal is now rock hard and you need to be measured on the brake pedal now as they bite like anything... You can modulate the braking very nicely which is fantastic... lots of feel in the pedal. Would highly recommend the pads to anyone looking for a rally/race pad. Very much hello head have you met mister windscreen affair. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted August 15, 2011 Author Share Posted August 15, 2011 Run 1 from a Bent Sprint i did on Sunday. This was the slowest run of mine for obvious reasons. The quickest was 5 seconds faster. (can be viewed in hd) Runs 2 & 3 i had camera issues. Quote Link to comment Share on other sites More sharing options...
drtdvl Posted September 25, 2011 Author Share Posted September 25, 2011 So finally after 1 yr of waiting the torsion bars finally showed up! This week gave them a good cleaning and painted them to stop them rusting. A friend and I fitted them to the car today and it's made a very nice difference! Worked out that the 19mm bars had an effective spring rate of 92lbs and the new 22mm bars have a rate of 168lbs... or roughly 82% stiffer. or something like that as i can't remember the exact numbers in my head. We took 5mm out of the shock bolt distance to drop the ride height, and with the increased strength of the torsion bars it's raised the car about 15mm Quote Link to comment Share on other sites More sharing options...
Snoozin Posted September 26, 2011 Share Posted September 26, 2011 Heard there's a trackday on Saturday mate. Test the torsion bars out? Quote Link to comment Share on other sites More sharing options...
