DRTDVL's 1988 Peugeot 205 GTI
drtdvl
  • Replies 98
Not missing something. The are very very light in the rear, the whole car is around 850kg we think.
Most of the gravel guys run 21mm bars, tarmac rally guys run a 23mm setup, and track setups are 25+ with some running 28mm.
I went with a compromised 22mm setup which i can't remember why but i think it was to do with how many wet events we have here and the bumpyness of our roads. Either way i'll get more in the future for gravel and track... so yeah.
The fronts i'll be looking at 350lbs as i think i've currently got 250lbs in at the moment and it's a bit soft.
started making the blanking plates for the spotlights. I'll need to get Matt to give me a hand with the rest of it.
Laid a crap load of rubber grease, chassis grease, and silicon lube spray to prevent the space invader foam from sticking to the bumper. It worked very very well.
Went for a lovely drive saturday with a friend and a short little drive with TooT TooT Timmay as passengers.
Car is handling very nicely with the new torsion bars but it has made the need to be smooth mid-corner much more evident as it will step out on you very easily.
This weekend i'll try and get another friend to give me a hand and swap over the sump with my baffled one and reseal the damm thing so it doesn't leak. Then fill with some nice new oil, new filter... then play time mid-week at Hamptons for the Unkles thing i'm thinking!
I'll also needed to look at cutting some air holes for the oil cooler in the bumper as now with the lip it's not getting much air and it's really working that well. Got the hole saw and stanley knife out and hacked up my silver bumper... Placed some nylon mesh on the backside of the hole for larger stones, i'll have to see how it holds up before looking at improvements.
Have ADOS F2 stuck to my fingers now tho, it's sticky...
  • 5 months later...
Bit of an update:
Found a couple nice little bits that will be ordered this year from a UK company called Bridgecraft Engineering - blurb from the 306 forum:
"Our main line of business is manufacturing aerospace components for the likes of Rolls Royce and Pratt and Whitney, as well as various forms of motorsport including F1 and MotoGP.
We have an ever growing range of Peugeot related parts which have been developed on Martin’s 306 track car and my own 309 and 205. We never really intended to market any of our parts but due to the increasing interest we thought it'd make sense to list a few of our products for you all to see."
Should help with a few things.
Bridgecraft Roll-Centre Kits:£95 plus p+p. The price will also include an abrasive stone that can be used in a hi-speed gun drill to chamfer your hubs.
The main body is cnc machined in house from EN24T and gives 30mm of correction. The full kit consists of the main body,laser cut side braces,zinc coated hi-tensile bolts, washers and nyloc nuts. The kit is per car so theres two sets of everything.
Bridgecraft Bump Steer Reduction Kit: £100 kit only
2x high quality rose jointed TRE, 2x EN24T sleeved spacers and washers, High tensile bolts and nyloc nuts
This kit requires the TRE taper in the hub to be accurately drilled out to 16mm.
They also do a couple other nice little bits like:
- Negative camber rear arms: £175 - Machining of your trailing arms and fitting of new EN24T stub axles to give -3 degrees of negative camber.
- Negative camber front hubs: £140 - We can modify 205/309/306/405/406 front hubs to give any amount of negative camber you require.
Some progress on the blanking plates for the spot lights that a friend is helping with and took some pics of his progress...
You can see how it's going to extend past the spotlight hole blanking the complete hole.
Once the skin gets applied it should look something like this
Front sub-frame is all now nicely welded up (except for the sections I did)
It's sounds a lot more solid when it bangs on the ground and dosn't really feel any heavier.... It looks like it was basically 4 sections of 3mm thick steel spot welded in a few places so based on the feedback from those overseas that have done it already it should stiffen up the front end a fair bit. We have reinforced the control arm mounting points a fair bit with extra welds.
no pics of mine but it's like this:
