DRTDVL's 1988 Peugeot 205 GTI
drtdvl
Photos:
th_DSC00696.jpg th_DSC00695.jpg th_web7.jpg th_web8.jpg th_web9.jpg th_web4.jpg th_IMG_7803.jpg th_IMG_7800.jpg th_IMG_7780-1.jpg th_MG_0673.jpg th_MG_0675.jpg th_MG_0623.jpg th_es_drive15.jpg th_es_drive2.jpg th_es_drive7.jpg th__MG_1572copy.jpg th__MG_1616copy.jpg th__MG_1619copy.jpg
Basic history:
It started life as a white 1.6 gti and was used as a press-car (i've got the original NZ Car mag where it was on the cover being thrown around a gravel quarry.) In 2002 the pervious owner - Mark Herbert -built the car for the 2002 Dunlop NZ Targa, and unfortunately didn't finish the race due to an accident. Mark repaired the car and then it's sat in his workshop waiting for the finishing touches to be done since then.
In 2008 went to see Mark to price up a rollcage for the 306, after 30 min of looking at the rollcage in the 205 to show me was he would do - i was sold - nice rollcage it was going to be... Mark then as i was walking out the door asked if i would like to buy the 205. I took 1 day for me to confirm that i could purchase the car - re: The GF approving that i spent the money on buying the car instead of a trip to the states, which as you can tell by reading this it was...
The car will be used for tarmac events until i can afford the undercar protection and gravel suspension - so i'm figuring a few years off... (note: 2 yrs later i'm still not able to afford it... hehe)
Engine:
Oil Cooler = 11 Row external (i think it's 11 row) Mocal
Engine = 405 MI16 4WD XU9J4
ECU = 405 MI16 4WD XU9J4 + Peter T Chip
Engine Mounts: Customised Factory Top mount, Aftermarket Uprated Lower Mount, factory gearbox mount
Sump = Customized Sump (Windage Tray, Increased Volume, Modified front)
Fuel Lines = moved into cabin, all braided lines
Oil Breather System = Custom
6-Bar PTS Oil Pump Spring
Custom Heat Shield
Washer bottle = 309 rear bottle
Spec:
Dyno’ed at 128hp at the wheel at 7500rpm (rev limit)
Suspension:
Rear:
Cut down 306 S16 24mm anti-roll bar
Rebuilt rear beam.
Solid BakerBM mounts (group a)
Spax Adjustable shocks
Factory 1.9 GTI Torsion Bars
Assuming 205 trailing arms
Front:
Bilstien Adjustable Coilovers (unknown spring/spring rate - est 200/250lbs)
Adjustable Camber / Caster Plates
306 S16 Hubs with stud conversion
Exhaust:
Custom 2.5 inch system, painted with Black High Temp paint
Gearbox / Drivetrain:
306 S16 driveshaft – gear box input end
405 CV’s
205 middle and hub driveshaft ends
306 S16 BE3 (same ratios as MI16)
Kevlar Clutch
Quaife automatic torque biasing helical gear LSD
Upgraded linkages
Custom Quickshifter
Phosphor Bronze bushes
Brakes:
Front:
Peugeot 307 XSP 283mm Disc / Calipers (rebuilt)
Peugeot 406 23.8mm Master Cylinder
Braided Lines
Middle:
Custom lines
Wilwood Adjustable Bias Valve
Hydraulic Handbrake
Rear:
1.6 GTI front calipers using standard rear disc (converted from drum)
Custom braided lines with banjo fittings caliper end
Body:
Painted Unknown Silver Color
Satin Black painted trim, door handles, wing mirrors, slam panel, skuttle plate, gti badges
E30 Pre-Facelift lower lip – modified to fit
206 GTI rear wing – modified to fit
Sump Guard
Clear front indicators
405 arms wiper and 306 blades (larger sweep area)
205 “Automatic” Bonnet
Spotlights cut out of Bumper
Rear 1/4 windows = Lexan
Sideskirts have had jack mounts fabricated into them
3M High Temp Foil Tape along trans-tunnel
88 GTI wing mirrors (smoother and smaller then later gti mirrors)
Interior:
Battery behind co-driver’s seat
Water Temp, Oil Temp, Oil Pressure gauges
Electric Kill Switch
Interior Panels replaced with Carbon Fibre Panels
Chrome-Molly Roll Cage
Interior Completely stripped bar Roof Liner
Dash modified to fit rollcage
Seats = Racetech 4009w (D) & Racetech 4000 (P)
Belts = Racetech (TRS) 3inch 6-point
Steering Wheel = Momo Race
Flooring = Checker Plate, sound deadening removed
Terraphone Professional Amplifier + 2 x touring head sets
Custom Extended Steering Wheel Shaft
Wheels:
4 x 15inch ROH Astrons
4 x 306 S16 rims
4 x 405 MI16
2 x 205 GTI “speedlines”
Future Plans:
22mm Torsion Bars, 25mm Anti-Roll Bar
Rebuild front bilstiens, new rear bilstiens, new front springs
1.9 GTI Hubs, 309 control arms, 309 rod ends, Quaife Quick Steering Rack, 309 Middle driveshaft components
Seam Welded front subframe
New Engine mounts
Carbone Loraine RC6 Pads
Aftermarket ECU, Quad Throttles, Upgraded Cams
Custom Gearbox – S16/MI16 1st, 2nd, Final Drive – 1.6 GTI 3rd, 4th, 5th
  • 4 months later...
  • Replies 98
may i ask why its making all its power on redline?
larger exhaust, shortened intake manifold, and unknown engine work would be my assumptions but ya no idea? We extended the rev limit from 7200 to 7500 and it's just starting to flatten off now.
Red = pre-chip, blue = post chip... runs done back to back
ignore the rpm's they didn't match up for some reason.
Installed the new Carbone Lorraine RC6 pads are FRICKEN AMAZING!... 100% Sintered metal pad, No bedding in required, and work amazingly well when cold.
Pedal is now rock hard and you need to be measured on the brake pedal now as they bite like anything... You can modulate the braking very nicely which is fantastic... lots of feel in the pedal.
Would highly recommend the pads to anyone looking for a rally/race pad.
Very much hello head have you met mister windscreen affair.
So finally after 1 yr of waiting the torsion bars finally showed up!
This week gave them a good cleaning and painted them to stop them rusting.
A friend and I fitted them to the car today and it's made a very nice difference!
Worked out that the 19mm bars had an effective spring rate of 92lbs and the new 22mm bars have a rate of 168lbs... or roughly 82% stiffer. or something like that as i can't remember the exact numbers in my head.
We took 5mm out of the shock bolt distance to drop the ride height, and with the increased strength of the torsion bars it's raised the car about 15mm
