Jase Posted August 16, 2010 Share Posted August 16, 2010 got a few scoots for reasons yet to be found, cf50 chaly 3 speed auto to be grass track racer, plans are use ct suspension and retain little wheels for max speed/lols, fix oil leak and change bars cd90 classic resto/mod ct110 engine 8 speed to be commuter ct110 learning bike for the girlfriend, beer delivery and hot laps round the house picked up ct and parts ct today will be wrecking some bits Quote Link to comment Share on other sites More sharing options...
Jase Posted August 16, 2010 Author Share Posted August 16, 2010 had a fang on the ct tonight everything works bar indicators, was running super rich so gave it a little tune, have to finish insulation under the house this week then i'll cut into pulling down the parts ct and getting the chaly ready for racing 29th Quote Link to comment Share on other sites More sharing options...
Jase Posted October 26, 2011 Author Share Posted October 26, 2011 jebus thread revival wednesday, bought a lifan 125 and relaced some rims, shit nearly be rolling, started intake manifold as it stands and my second ever wheel relace its not rocket science but shit its satisfying Quote Link to comment Share on other sites More sharing options...
EURON8 Posted October 26, 2011 Share Posted October 26, 2011 I recently discovered that one of the pies my boss has his company owning fingers in is lifan (the NZ agency that is). Quote Link to comment Share on other sites More sharing options...
Jase Posted October 26, 2011 Author Share Posted October 26, 2011 handy to know they're a good little honda copy i've had dealings with for the last 7 years, they don't seem to give up too easily, hopefully i'll finish the front wheel tomorrow and have the tyres back on before next days off Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 26, 2011 Share Posted October 26, 2011 Oh man this hog is going to be dreamy when done. bloody good engines. Quote Link to comment Share on other sites More sharing options...
Jase Posted October 27, 2011 Author Share Posted October 27, 2011 wheel laced ready for truing, have to find me some bmx forks to make a stand Quote Link to comment Share on other sites More sharing options...
Mr.Mk1 Posted October 27, 2011 Share Posted October 27, 2011 Such a mean collection boe! Quote Link to comment Share on other sites More sharing options...
Jase Posted October 29, 2011 Author Share Posted October 29, 2011 got tyres back on and back on the floor its fairly small compared to me, how do i hook a non battery supply system into a battery supply to run lights battery etc? Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 29, 2011 Share Posted October 29, 2011 surely the only reason you'd want a battery is for leccy starting? otherwise just use a regulator so you don't pop bulbs and a kick... Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted October 29, 2011 Share Posted October 29, 2011 ^ this. battery can help indicators etc work a bit better though? I think if you're pre '78 or something you can get away with not running a headlamp all the time on the road, and don't have to have indicators? I'd run no battery if you can though. and yeah, a rectifier/regulator/whatever to stop the bulbs popping all day. such a sweet little machine man. state of decay it's in, plus semi offroad oriented tread pattern makes me swoon. love it! Quote Link to comment Share on other sites More sharing options...
Jase Posted October 29, 2011 Author Share Posted October 29, 2011 not too sure which way to go, it hasn't got an electric leg but i do want to have fully functional lights etc so their would be little reason to pull me over, and i finish my nights at 4.30am so i like the idea of having a decent possum blinder on the front for rolling home, i have a 6 wire stator on the lifan but have yet to find a decent wiring diagram to set it up either way. I know with the CT it was battey dependant to run but still had a piss week light setup(piss runs through the park proved this). I'm lengthening the intake runner by at least an inch and running the og dream air filter. I could drag 80-85kph out of the ct so it will be interesting to see if i can attain a comfortable 55mph with the right gearing. Quote Link to comment Share on other sites More sharing options...
tortron Posted October 30, 2011 Share Posted October 30, 2011 small gel battery with solar trickle charger? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted October 30, 2011 Share Posted October 30, 2011 Our 125 lifan engines dont put out much voltage, not enought to mantain a charged circuit. With a new battery can get an hour night ridding with new battery. Have found if you replace everything with LED bulbs you get a bit longer between battery requiring charge. odity n co had to re wire for 12v instead of C90's 6V not sure if your is same. Quote Link to comment Share on other sites More sharing options...
10Speed Posted October 30, 2011 Share Posted October 30, 2011 I have a bike with a 10w lighting coil which translates to no power at all. I have fitted LED's to that to make the most of the power and still get a strobe at idle. Late I will experiment with some capacitors to try and smooth it out a bit (though as far as I can tell capacitors are mostly magic and there's no reliable (easy) way to calculate what you need...) Quote Link to comment Share on other sites More sharing options...
Jase Posted November 2, 2011 Author Share Posted November 2, 2011 new riding outlook flat bars possibly go drop if i find something (i have bent xr bars that could flip) next is remove half the foam from the seat as its too tall and out of preportion. then get the intake and exhaust sorted Quote Link to comment Share on other sites More sharing options...
Jase Posted November 3, 2011 Author Share Posted November 3, 2011 quick slap intake manifold had some ugly as fuck welding so filed and dremelled the living shit out of it, needs a final file and sand before it gets some paint Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted November 3, 2011 Share Posted November 3, 2011 so keen to see how this performs, my v50 will be getting the same treatment in the near future. loving the style here, definitely needs a lower profile seat and smaller bars like you say. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted November 3, 2011 Share Posted November 3, 2011 Chunky tyre looks dope. chop seat so its shorter length, drop the rear and shorten guard winning Quote Link to comment Share on other sites More sharing options...
isnowi Posted November 3, 2011 Share Posted November 3, 2011 Solo seat could work in a 'that so doens't suit the style of bike' kind of way.. Quote Link to comment Share on other sites More sharing options...
