rwdlancer Posted July 20, 2009 Share Posted July 20, 2009 Hi, Got my front shocks for my lancer shortened and now i need to replace the oil that was in them.there the type of shocks that come apart, just wondering what kind of oil i should put in them? help would be great thanks Quote Link to comment Share on other sites More sharing options...
mekemelorry Posted July 20, 2009 Share Posted July 20, 2009 I just used engine oil in my starlet ones. Quote Link to comment Share on other sites More sharing options...
shizzl Posted July 20, 2009 Share Posted July 20, 2009 go to a motorbike shop and buy some shock oil Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted July 20, 2009 Author Share Posted July 20, 2009 haha engine oil aye.sounds a bit ruggd.did it work all good? is shock oil epensive? Quote Link to comment Share on other sites More sharing options...
Borgweiser Posted July 20, 2009 Share Posted July 20, 2009 If repco still sells Jack oil id use that as worked mint for me in the past, havent seen it in ages tho Prob get at supercheep, often called Hydraulic oil- not to be confused with hydraulic fluid Quote Link to comment Share on other sites More sharing options...
UTERUS Posted July 20, 2009 Share Posted July 20, 2009 Put ep90 in there if you are keen for sphincter shaking Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 20, 2009 Share Posted July 20, 2009 Most Bicycle shops have varying rates of oil from 2.5w through 40w Why not just buy new inserts from Autolign/BnT - will save you a lot of hassle.. Oh wait you have already shortened the factory ones -- seems pointless to me with factory ones being so shit... Quote Link to comment Share on other sites More sharing options...
tortron Posted July 20, 2009 Share Posted July 20, 2009 If repco still sells Jack oil id use that as worked mint for me in the past, havent seen it in ages thoProb get at supercheep, often called Hydraulic oil- not to be confused with hydraulic fluid yea they sell jack oil, just got some. was pretty cheap too Quote Link to comment Share on other sites More sharing options...
durty Posted July 20, 2009 Share Posted July 20, 2009 diff oil ftw Quote Link to comment Share on other sites More sharing options...
ProZac Posted July 20, 2009 Share Posted July 20, 2009 Can get motorcycle fork oil thru repco, think in 5w, 10w and 20w. Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted July 21, 2009 Author Share Posted July 21, 2009 yea i should of just got new shocks but ive done it now.i was thinking of putting hydraulic oil in just dont no if its gna eat away at the oil seals in the shock and fuck it. wht you guys rekon? the bike fork oil sounds like the one Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 21, 2009 Share Posted July 21, 2009 how much did it cost you to have the shocks shortened? Personally I would cut your losses and buy brand new gas inserts and shorten them.. I was a mechanic for 13+ years and never put a factory hydraulic setup back together - I always replaced them with new inserts.. I am assuming if they were put back together, even if done properly with new seal kit (if you can buy these still??) they will not last long till they start leaking and need replacement again.. caused by wear and tear on the sleeve and piston from 20+ years of driving.. Quote Link to comment Share on other sites More sharing options...
rwdlancer Posted July 23, 2009 Author Share Posted July 23, 2009 cost me 50$ to get both shocks shortened.have sorted them now went and bought heavy shock absorber oil (20w) from the motorbike shop and it works well.shocks are very stiff. cheers for the help os bros Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 23, 2009 Share Posted July 23, 2009 diff oil ftw nah dont do that you can bend the shock rod. 910 has had 10w oil and now 50w now ...sure its stiffier , but only on the rebound so you'll still dive on first compression . how much did it cost you to have the shocks shortened?Personally I would cut your losses and buy brand new gas inserts and shorten them.. I was a mechanic for 13+ years and never put a factory hydraulic setup back together - I always replaced them with new inserts.. I am assuming if they were put back together, even if done properly with new seal kit (if you can buy these still??) they will not last long till they start leaking and need replacement again.. caused by wear and tear on the sleeve and piston from 20+ years of driving.. yea man new shocks are just soo much better Quote Link to comment Share on other sites More sharing options...
