danger Posted July 16, 2009 Share Posted July 16, 2009 First of all, Fuck my life. Second up I'm swapping my ute tomorrow and just came home from the pub to find house stinking of pertol cause b1600 fuel tank is pissing out petrol ASAP FIXING IDEAS THANK GO: Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 16, 2009 Share Posted July 16, 2009 Soap Quote Link to comment Share on other sites More sharing options...
macabre Posted July 16, 2009 Share Posted July 16, 2009 soap, or metal cement. Quote Link to comment Share on other sites More sharing options...
macabre Posted July 16, 2009 Share Posted July 16, 2009 snap ^^ Quote Link to comment Share on other sites More sharing options...
karmagedon Posted July 16, 2009 Share Posted July 16, 2009 soapy duct tape? super glue? but metal cement whatever that is sounds good Quote Link to comment Share on other sites More sharing options...
Unclejake Posted July 16, 2009 Share Posted July 16, 2009 Lols. TBH once upon a time when rushing to a Helicopter down a gravel road for a deer stalking mission I holed the tank in my Alfa GTV. I rubbed untold soap into the split. Didn't work. Lubs. Quote Link to comment Share on other sites More sharing options...
danger Posted July 16, 2009 Author Share Posted July 16, 2009 Remembered I gave a mate a mint one so shall go collect it this morning whether its fitted or not. Guy doing the swap is quite a GC about it. probably cause his cars a timebomb Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 16, 2009 Share Posted July 16, 2009 Lols.TBH once upon a time when rushing to a Helicopter down a gravel road for a deer stalking mission I holed the tank in my Alfa GTV. I rubbed untold soap into the split. Didn't work. Lubs. I believe it's the "Ivory Soap" that does that trick and not just any old soap. Quote Link to comment Share on other sites More sharing options...
tortron Posted July 16, 2009 Share Posted July 16, 2009 weld it faggot Quote Link to comment Share on other sites More sharing options...
mikuni Posted July 16, 2009 Share Posted July 16, 2009 just knead-it Quote Link to comment Share on other sites More sharing options...
durty Posted July 16, 2009 Share Posted July 16, 2009 knead it will be sweet as Quote Link to comment Share on other sites More sharing options...
danger Posted July 16, 2009 Author Share Posted July 16, 2009 Well other tank didnt fit so I soldered up the holes and am going to cover in knead-it Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 17, 2009 Share Posted July 17, 2009 Tried using that stuff to seal an extremely small hole in sump but just seeped around the side. Different temperatures and density fluid i guess. bubble gum? Quote Link to comment Share on other sites More sharing options...
mikuni Posted July 17, 2009 Share Posted July 17, 2009 Tried using that stuff to seal an extremely small hole in sump but just seeped around the side.Different temperatures and density fluid i guess. If you took the sump off, degreased it and applied it right it should have worked as a temporary measure. If you just jammed it on over top of all the oil and crap it won't work. If you were to whip the sump off you might aswell get it welded any way though so kind of defeats the purpose. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 17, 2009 Share Posted July 17, 2009 This was an emergency slap it on the bottom, the night before admins wedding situation But yeah that stuff sets extremely hard! Wish some cunt didn't put it all in my pillar, its making the rust repair double hard! Quote Link to comment Share on other sites More sharing options...
danger Posted July 17, 2009 Author Share Posted July 17, 2009 Welded it and put knead it over the top now its finally fixed. Soldering didnt stick too flash. Quote Link to comment Share on other sites More sharing options...
Hemi Posted July 17, 2009 Share Posted July 17, 2009 Tried using that stuff to seal an extremely small hole in sump but just seeped around the side.Different temperatures and density fluid i guess. bubble gum? funny you say that , working uncles rally team and he punctured the fuel tank ... i used a mintie to stop the leak ...i shit you not .. and it lasted 2 weeks before the tank was pulled and replaced as matter of course ... uncle wrote in to have it put on the wrappers lol .. Quote Link to comment Share on other sites More sharing options...
danger Posted July 17, 2009 Author Share Posted July 17, 2009 Well it was fixed till i left it outside overnight in a frost... FUCK. Quote Link to comment Share on other sites More sharing options...
Jase Posted July 17, 2009 Share Posted July 17, 2009 i have a spare b16 fuel tank 1977 model Quote Link to comment Share on other sites More sharing options...
QCADTA Posted July 17, 2009 Share Posted July 17, 2009 plug n dyke, belzonea or stag, probably not spelt right but all work a treat. Quote Link to comment Share on other sites More sharing options...
