toyotaloyal Posted April 21, 2010 Share Posted April 21, 2010 BAhahaha - ya quitter! keep std 4age distributor and buy a hyperpak to control it- best thing to do when runing carbs. http://www.erd.co.nz/products/toyota.html Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 21, 2010 Share Posted April 21, 2010 well after ditching the car half way home (short in fuel pump wiring or something popping fuses) and walking home from houghton bay at 1am i had some thinking time haha. ready to quit now! ooh hyperpak looks sweet Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 22, 2010 Share Posted April 22, 2010 wonder if my ecu is different in how it switches fuel pump Also i told you to text me if you had problems you wanker. will call glen now Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 22, 2010 Share Posted April 22, 2010 well by the time i'd fucked around then run up top of the hill to get phone reception you'd have been in the hutt by then! gona let the car sit and get on with other shit for a while. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 22, 2010 Share Posted April 22, 2010 and conclusion of call was that very likely not the TPS. hmmm...... sorry man Allan Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 22, 2010 Share Posted April 22, 2010 r1 carbs plez. Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 23, 2010 Share Posted April 23, 2010 This has to be the most difficult bluetop wire up in the world! I feel for you man, just burn it? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted April 23, 2010 Share Posted April 23, 2010 just fix your fuel pump issue and you will be sweet. i would say with resistors removed your lean issue will be gone, and you said it goes hard when you have the timing set up like you have had it. i think your all sorted really man. Swap ecu, see if uel pump still blows, if it does we can sort one from somewhere. you will be away laughing haha Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 23, 2010 Share Posted April 23, 2010 hhmmm.. it'll never stop bothering me man.. and even when it is running 'well' on super silly timing it will only start nicely when it's stone cold and from then on it takes 10 attempts to start it with all sorts of shudders and crazy shit going on. possibly a temp sensor thing? oh wait yeah weve already checked that shit out haha funny you mention burning spence, with the fuel pump issues the other night i had images in my head of a picturesque kp60 bonfire on the south coast, would have been soothing at the time! Quote Link to comment Share on other sites More sharing options...
Toucan Posted April 23, 2010 Share Posted April 23, 2010 I feel your pain man. But keep at it, was worth it when I got mine sorted. Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 23, 2010 Share Posted April 23, 2010 Fro starters just wire up the fuel pump up on a relay from the key for now to eliminate that issue. Something sounds up the fuck big time with this thing Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 23, 2010 Share Posted April 23, 2010 ^ thats how i had it before, i'm pretty sure the fault is in the pump or its wiring, not the ecu side of things. it was blowing fuses as soon as i turned the key on, well before the relay even gets a signal to switch the pump on! only thing i'll be doing on the starlet for a while is getting the beers out from under the seat. Quote Link to comment Share on other sites More sharing options...
AE25 Posted April 24, 2010 Share Posted April 24, 2010 so dodge fuel pump wiring causing pump not work? lean out etc. sounds like easy fix? Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 25, 2010 Share Posted April 25, 2010 not too worried about the fuel pump, will be an easy fix. but it'll still have stupid timing retard problem, being the main problem all along. Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted July 12, 2011 Share Posted July 12, 2011 This thread is interesting, but it goes from 2 seperate things and kinda makes it confusing. From my understanding and study so far... Dizzy coil ignitor - timing stuff <<< main area to focus - but once its left the dizzy cap its of to the leads and plugs so it cant be that stuff past that point. TPS, MAP sensor, Manifold temp, - regulates fuel by adjusting the injector pulse width. If not enuff gas will cause surges. Always the simple things are overlooked. Earths are the major. Check all the brown wires, to be sure run earth from engine (this means block and also inlet manifold so 2) to chassis, battery to chassis, ecu to engine. ecu to chassis. No change. earths eleminated. no harm in running earths. But reading it sounds like its retardin when it should be advancing... DIZZY will be the first port of call. If youve rewired the thing the wire widths or amount of current flowing will matter greatly (fat wires less resistance). I havent yet started to wire my 4age so im expecting to find that it wont go that easy. So one also told me about JDM stuff and other stuff being mis matched, all stuff should be standy bluetop... There was a tech article somewhere about redoing the dizzy bearing and it explains the wires inside as well... And plenty of bench going 4AGES feature on billy sherwoods page! another good place to look too. Swap ECU over? Swap Ignitor? Dont go to carbs... see it through... you will scream joy when it works and dry hump anything in site. Quote Link to comment Share on other sites More sharing options...
Spencer Posted July 13, 2011 Share Posted July 13, 2011 This is a pretty old thread! this car carbs now, he tried combinations of different ECU's, dizzys, looms etc Problem could be diagnosed in no time with a scope, check what the VR sensors are spitting out, see what the ECU in sending to the ignitor etc. Would narrow it down real quick Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 13, 2011 Share Posted July 13, 2011 yeah, still keen to run efi one day in the future, once i find a set of MATCHING SHIT to put on haha. meanwhile, the carbs are all good, hyperpak hasn't missed a beat, and reliable starlet life is good! enjoying the look of carbs and the 4 wires it takes to run the ignition so going back to efi shit everywhere, no clearance on master cylinder bla bla etc isnt actually that appealing.. funny to see this thread rollin again Quote Link to comment Share on other sites More sharing options...
