EURON8 Posted December 21, 2008 Share Posted December 21, 2008 Hey guys, Failed wof on van, brakes, mirror, and tires so i brought some 5x114 wheels with mint tires to get the wof with. Went to bolt them on and the centre hole is smaller than the hub. So needs to be bored out. I know a few of you guys have had it done, What sorta price would i be looking at and can they do it with the tires on? I only got these wheels for the wof so dont wanna spend heaps on fitting them. heres hopin, Need it done ASAP, need Wof before newyears. chur Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted December 21, 2008 Share Posted December 21, 2008 you wud be hard presed to find a lathe that will do it with tyres on. so take em off. then prob a hour or to at a engineer. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted December 21, 2008 Share Posted December 21, 2008 Had this problem with the Hilux, Falcon rims fit over hubs judging by the foul rims that are on the ute now Quote Link to comment Share on other sites More sharing options...
escorted Posted December 21, 2008 Share Posted December 21, 2008 I would do it for A box of beers but i dont think i could swing it in my lathe. But a good engineer/turner could get it done in under an hour Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 21, 2008 Share Posted December 21, 2008 if its urgent just bust the die grinder out on it... most wheels arn't hubcentric and wof guys dont often check that they are Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted December 22, 2008 Share Posted December 22, 2008 Would be able to get away with using 5mm spacers? Quick, cheap fix, but not legal (I dont think) Quote Link to comment Share on other sites More sharing options...
lowlancer Posted December 22, 2008 Share Posted December 22, 2008 Nah. Have to be bolted on and then they have to be certed and 25mm max I believe Quote Link to comment Share on other sites More sharing options...
sentra Posted December 22, 2008 Share Posted December 22, 2008 when u get a wof how often do they actually take ur wheels off rofgl? wheel repair guys will have a flange/axle and run it in lathe so no need to remove tyre. try the place on gloucester park road next to workshop hes a gc as. 1 Quote Link to comment Share on other sites More sharing options...
EURON8 Posted December 22, 2008 Author Share Posted December 22, 2008 Thanks guys, Just got some tires for the current wheels, and will use the tires off these for my daily when i decide to get that a warrent. I found a place on the shore that would do them for $20 -$25 a wheel without tires on, but he couldn't do it before Xmas. Quote Link to comment Share on other sites More sharing options...
