kyteler Posted October 1, 2008 Share Posted October 1, 2008 Have you got any photos of the wishbone setup? Quote Link to comment Share on other sites More sharing options...
durty Posted October 1, 2008 Share Posted October 1, 2008 more pics of volvo wags? Quote Link to comment Share on other sites More sharing options...
Jase Posted October 1, 2008 Author Share Posted October 1, 2008 sorry durty no, its not mine, heres some pics of the setup its a bit grubby sorry parts car stuff, , they're quite short uprights but i would chane the set up to run qa1 coilovers any way if any major mods were needed like more than tie rods etc Quote Link to comment Share on other sites More sharing options...
Jase Posted October 23, 2008 Author Share Posted October 23, 2008 got some parts back from zinc today, pretty good finish although i missed a few spots and some paint had to be scraped off, not sure whether to paint it off as well or just leave it raw, also got my new bushes which are lovells for the control arms and nolathane for the sway bar links etc Quote Link to comment Share on other sites More sharing options...
Jase Posted November 10, 2008 Author Share Posted November 10, 2008 had good friend put my tires on and was going to drop it on the ground but still have clearance issues with width so will wait for the diff to get finished, also whacked the crossmember back in and dummy fitted the new sump, lil odd jobs but getting progress , whats your fellas thoughts, make a complete new custom sump from scratch or patch the old one? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 10, 2008 Share Posted November 10, 2008 just after some ideas guys i popped the x member off the other day but i'm running out of time with this, I have an xd lsd on the way and want to go discs all round, this may mean i either have to convert axles to 4x100 or i convert the whole car to 5x114, and be able to utilise a huge array of mags and brake components that are availible, i want to get it running first with the piazza front, gemi diff set up and at least be able to have a play, the problem there will be all my gearing is going to be quite low which is going to have me tapped out at 150km/h on 16's, so what cars have a similar wishbone set up that is 5x114, and the back end will be a four link with a watts eventually once it gets set up with an lsd, I know i take off in more directions than a windvane in a tornado but any ideas would be appreciated I think early L200 has similar wishbone and ford stud pattern Quote Link to comment Share on other sites More sharing options...
Jase Posted November 24, 2008 Author Share Posted November 24, 2008 any thoughts on the brake setup, need to find a disc combo in 28mm or 27mm with a low hat, evos may be close i think in 300mm preludes are not thick enough audis ditto Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 24, 2008 Share Posted November 24, 2008 What are measurements and I'll search in computer tomorrow by size and give you some options. Edit* and what stud pattern? Quote Link to comment Share on other sites More sharing options...
Jase Posted November 24, 2008 Author Share Posted November 24, 2008 296mm diameter or close by 28mm thick rotor with a 19 or 20mm hat i can have the mounts on the calliper milled to get the offset perfect, 47mm from top of hat to back of rotor is ideal 48mm is tight. centre bore is 68mm Quote Link to comment Share on other sites More sharing options...
Gaz Posted November 24, 2008 Share Posted November 24, 2008 Check Safari disks Bendawg.. they have a tiny/no hat. Quote Link to comment Share on other sites More sharing options...
Jase Posted November 25, 2008 Author Share Posted November 25, 2008 found the right ones dba 28o will sit fairly perfect with a little machining, 500sl mercedes rotors lol 300mm dia 45.5mm height 28mm thickness 67mm centre bore even borrowed some verniers to get more accurate, hope they aren't too expensive Quote Link to comment Share on other sites More sharing options...
CUL8R Posted November 25, 2008 Share Posted November 25, 2008 That zinc coating looks slick as man, seem to do far more progress than me Quote Link to comment Share on other sites More sharing options...
Jase Posted November 25, 2008 Author Share Posted November 25, 2008 haha not really man just try an get something happening each days off, should be finished on the axle front soon too and the steering rack has been modified too, its a money thing i suppose, spent close to 3 grand in the last 6 months to get it closer probly about 4g to go Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted November 25, 2008 Share Posted November 25, 2008 Did you get my texts dude?. Quote Link to comment Share on other sites More sharing options...
Jase Posted December 9, 2008 Author Share Posted December 9, 2008 lol will it stop lol maybe nose dive Quote Link to comment Share on other sites More sharing options...
EURON8 Posted January 27, 2009 Share Posted January 27, 2009 hey man, Did you make your own engine brackets? I just bolted the standard SD1 mounts to standard brackets and its to wide to meet up to the hiace crossmember. where brackets = the part that bolts to engine and mounts = the rubber bits that add flex. Trying to find out if other RV8 epuipped cars had shorter ones or if im gonna have to make something from scratch. Got pics of the mount setup? Quote Link to comment Share on other sites More sharing options...
Jase Posted January 28, 2009 Author Share Posted January 28, 2009 disco brackets would be what you want bro, mine are custom as stz but disco ones would have probably done the job if i could put the engine 6" back in the bay Quote Link to comment Share on other sites More sharing options...
Jase Posted January 28, 2009 Author Share Posted January 28, 2009 and segedins can have you rid the su's edelbrock mani's $350 to 4 barrell holley 390 vac sec or 450 dp work best Quote Link to comment Share on other sites More sharing options...
EURON8 Posted January 28, 2009 Share Posted January 28, 2009 disco brackets would be what you want bro,mine are custom as stz but disco ones would have probably done the job if i could put the engine 6" back in the bay Disco as in Discovery? Happen to know what car to look for? Quote Link to comment Share on other sites More sharing options...
Jase Posted January 29, 2009 Author Share Posted January 29, 2009 yeah boe discovery call morris at stag4x4 in aucks he should have some Quote Link to comment Share on other sites More sharing options...
