Alistair Posted June 7, 2007 Share Posted June 7, 2007 Im sure this has been done before, but im doing it again. Snapped a dumb bolt i was putting in for the engine mount on driver side, m12x50 1.5 thread pitch i belive. Now heres where it gets gay. I drilled it out to get out with bolt extractor. And the focking extractor broke inside there. GRR. Heniously pissed off as i was so close to getting it into the corona. All i have is gheylord cordless 18v drill with doesnt have the goods to sit there and drill it out. So whats my options. Send it to someone? Anyone on the shore that can help? I dont really want to take everything off it to transport it but if i have to so be it. Find a corded drill and go at it? Pretty gutted at this stage so all help welcome. Can take pic of said bolt if needed. Quote Link to comment Share on other sites More sharing options...
thminiman Posted June 7, 2007 Share Posted June 7, 2007 pic would be helpfull mang, Quote Link to comment Share on other sites More sharing options...
Alistair Posted June 7, 2007 Author Share Posted June 7, 2007 Picsss Second pic prob gives a better idea. Flash reflecting too much up close stz. Cheers Quote Link to comment Share on other sites More sharing options...
thminiman Posted June 7, 2007 Share Posted June 7, 2007 ahhhhhhhhhhhh, crap. you could try popping the screw extracter part out, as they're designed to come out pretty easy one way, and be tight as fuck the other way. or, get a carbide tipped drill bit. cos those screw extracter peices are made of hardened steel. Quote Link to comment Share on other sites More sharing options...
Alistair Posted June 7, 2007 Author Share Posted June 7, 2007 Tried that, not quite enough to tap it back out again. Weld something to it maybe? Quote Link to comment Share on other sites More sharing options...
thminiman Posted June 7, 2007 Share Posted June 7, 2007 possible, although im not sure how well you'll get on with welding to the extractor part, so would need to smash that out of the way first, then weld to the bolt. the extractor might also shatter depending on how big it is, hammer + pin punch or sumthing Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted June 7, 2007 Share Posted June 7, 2007 You will have to chisel the extractor out then welding to the remains of the bolt works well. Quote Link to comment Share on other sites More sharing options...
sentra Posted June 7, 2007 Share Posted June 7, 2007 if a few taps with mr centerpunch around clockwise doesnt get the extractor out, give up and take the block out. trying to use carbide/cobalt drills/gas torches etc in position just dulls enthusiasm for this shit, then you end up having to pull it anyway and loseing a full day you could have been drunk in. centerpunch works suprisingly well 1 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted June 7, 2007 Share Posted June 7, 2007 oh snap had this problem a few weeks back. ended up drilling out and using helicoil. hand drills take forever though, gutting you can't put the engine in a press haha. those ezy outs = so gay. ALWAYS break. tap it style ones are the meke. my old man's got a set he got before he even started his apprenticeship. still so good Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted June 7, 2007 Share Posted June 7, 2007 tack tack tack tack tack tack with mig on highish power, then unscrew with vice grips! try it. savd my ass a few times Quote Link to comment Share on other sites More sharing options...
Goat Posted June 7, 2007 Share Posted June 7, 2007 This happened to me on an intake manifold. Had to dremmel out the bolt around the broken off remover bit. Then had to helicoil it. An absouloute pain of a job. But it happens. eke_zetec_RWD's idea with the mig FTW!!. Just dont weld the bolt to the block Quote Link to comment Share on other sites More sharing options...
lowlancer Posted June 7, 2007 Share Posted June 7, 2007 Easy fix bowl Get bigger drill bit made of awesome material, drill out, then tap thread into hole I used my gaylord cordless drill from warehouse on cast shit before, just gotta have the right drill bits Quote Link to comment Share on other sites More sharing options...
Toucan Posted June 7, 2007 Share Posted June 7, 2007 Screw extractors suck. Worse comes to worse leave it in there and extend the engine mount along to bolt onto the bottom alternator bracket Quote Link to comment Share on other sites More sharing options...
danger Posted June 9, 2007 Share Posted June 9, 2007 Either put a nut over it and mig it together and try unscrew or at worst borrow a drill and good bit and put a helicoil in. Quote Link to comment Share on other sites More sharing options...
Alistair Posted June 9, 2007 Author Share Posted June 9, 2007 Yuh, going to get some decent bits tomorrow. Will see how it goes :S Quote Link to comment Share on other sites More sharing options...
