pies Posted January 3, 2007 Share Posted January 3, 2007 toyota 18r is randomly miss firing when driving down the road (note: not missing when car is turned off) no apparent pattern. just, misses. under power, cruising, up hill, down hill, gave the diz rotor a light sand. no help. checked cap, bit white on the contact points. brand new leads. plugs = all good. sprayed remains of can of carb cleaner down the carb throat. anything else i could try? Quote Link to comment Share on other sites More sharing options...
Guest kornstar Posted January 3, 2007 Share Posted January 3, 2007 (note: not missing when car is turned off) rofl Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 3, 2007 Share Posted January 3, 2007 fuck, chuck a new cap and rotor at it you tired cunt. you get them cheap enough also condensor/point if it's got them. fuck i dont care fuck off Quote Link to comment Share on other sites More sharing options...
pies Posted January 3, 2007 Author Share Posted January 3, 2007 fuck, chuck a new cap and rotor at it you tired cunt. you get them cheap enoughalso condensor/point if it's got them. fuck i dont care fuck off fuck you tooooo you aint gettin my sloppy seconds now. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 3, 2007 Share Posted January 3, 2007 Only doing it on part throttle, or on full throttle as well? Cunt Quote Link to comment Share on other sites More sharing options...
pies Posted January 3, 2007 Author Share Posted January 3, 2007 Only doing it on part throttle, or on full throttle as well? Cunt both. snoodler Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 3, 2007 Share Posted January 3, 2007 Bugger...the wagon was doing a similar thing, but only on part throttle. Oscar in all its homoness lists BP5ES's, but the Haynes/Toyota manual specifies BP5EY. Silly little groove made all the difference in the world, so it might pay to hunt around and make sure you've got the right plugs in there. Quote Link to comment Share on other sites More sharing options...
pies Posted January 3, 2007 Author Share Posted January 3, 2007 Bugger...the wagon was doing a similar thing, but only on part throttle. Oscar in all its homoness lists BP5ES's, but the Haynes/Toyota manual specifies BP5EY. Silly little groove made all the difference in the world, so it might pay to hunt around and make sure you've got the right plugs in there. will give it a shot au maybe iridiums heh Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 3, 2007 Share Posted January 3, 2007 Take the 18R out and put a 7M in. Sorted. Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted January 3, 2007 Share Posted January 3, 2007 Take the 18R out and put a 7M in.Sorted. fuck the 7m get a 1jz , is it fuel injected or carbie 18r, Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 3, 2007 Share Posted January 3, 2007 Take the 18R out and put a 7M in.Sorted. fuck the 7m get a 1jz , is it fuel injected or carbie 18r, Yeah, but if we're talking Cressida's, some came with 4Ms, so a swap to a 7M is a lot easier than a 1JZ, hence why I said 7M. Besides, wouldn't you go 2JZ if you were going JZ? Also, baked pastry goods. Check all your ignition earths, if it's intermittent, it's likely that it's something in the ignition circuit losing power. Check the condition of the barrel as well as the wires running from it. A friend had a similar problem in his 260Z 2+2 which turned out to be a slight nick in a wire in the ignition barrel loom, luckily no more than 5cms from the barrel so saved a lot of dramas, that was of course after we spent countless hours trying to find the damn problem, we swapped ECUs, Coils, Dizzy's, he changed injectors, fuel pump, filters.. even took it to a mechanic when we were lost. Mechanic was fucken useless and couldn't find the problem either. It was only when I gave him another ignition barrel to try that he stumbled across it. Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted January 3, 2007 Share Posted January 3, 2007 Take the 18R out and put a 7M in.Sorted. fuck the 7m get a 1jz , is it fuel injected or carbie 18r, Yeah, but if we're talking Cressida's, some came with 4Ms, so a swap to a 7M is a lot easier than a 1JZ, hence why I said 7M. Besides, wouldn't you go 2JZ if you were going JZ? Also, baked pastry goods. Check all your ignition earths, if it's intermittent, it's likely that it's something in the ignition circuit losing power. Check the condition of the barrel as well as the wires running from it. A friend had a similar problem in his 260Z 2+2 which turned out to be a slight nick in a wire in the ignition barrel loom, luckily no more than 5cms from the barrel so saved a lot of dramas, that was of course after we spent countless hours trying to find the damn problem, we swapped ECUs, Coils, Dizzy's, he changed injectors, fuel pump, filters.. even took it to a mechanic when we were lost. Mechanic was fucken useless and couldn't find the problem either. It was only when I gave him another ignition barrel to try that he stumbled across it. For the avergae person 2jz is not much point you are looking at arounb 3k mark where as a 1jz can be picked up for as little as 1g and are a awsome engine way better than any m sereis engine easy 300kw for any jz sereis of motor with good ecu big sinbgle and 15psi Quote Link to comment Share on other sites More sharing options...
kyteler Posted January 3, 2007 Share Posted January 3, 2007 For the avergae person 2jz is not much point you are looking at arounb 3k mark where as a 1jz can be picked up for as little as 1g and are a awsome engine way better than any m sereis engine easy 300kw for any jz sereis of motor with good ecu big sinbgle and 15psi So it's decided then. baked pastry goods will get an engine transplant. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted January 3, 2007 Share Posted January 3, 2007 chuck me down for a jz too Quote Link to comment Share on other sites More sharing options...
Honda Ass Dragger Posted January 3, 2007 Share Posted January 3, 2007 jz only way to go, easy 300kw motor hehe and 1jz can be had for 1000 dollars and only about 1500 to manual convert no excuses Quote Link to comment Share on other sites More sharing options...
Hemi Posted January 4, 2007 Share Posted January 4, 2007 id say take for run and pull plugs out , they can tell you quite a bit e.g too much fuel , not firing(no spark at plugs) , too lean etc etc , also check vacuum pipe from dizzy if it has one and the condenser can make the car run like a bag of shit if its poked Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 7, 2007 Share Posted January 7, 2007 buy a new cap and rotor buddy, honestly for the moeney, its the best way, also maybe try the condensor, although, might not be the problem, why dont you ask me these things when you see me fool........ Allan Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted January 7, 2007 Share Posted January 7, 2007 and my mark 2 will be getting all might 1jz power Allan Quote Link to comment Share on other sites More sharing options...
pies Posted January 7, 2007 Author Share Posted January 7, 2007 buy a new cap and rotor buddy, honestly for the moeney, its the best way, also maybe try the condensor, although, might not be the problem, why dont you ask me these things when you see me fool........Allan i knew u would say cap and rotor allready done. should have a condensor at work in the next few days Quote Link to comment Share on other sites More sharing options...
nismo.capri Posted January 8, 2007 Share Posted January 8, 2007 How does it miss? does it miss and loose power then clean up or is it just random misses? Injected or carbed? Does it have an O2 sensor? If it does watch the O2 and see if it leans out just before the miss, if it does you probably have a fueling issue. Quote Link to comment Share on other sites More sharing options...
