drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 i just made me a exchast for my rolla the other day bit of a mission to do at home. i ended up making it 2.25", the engine is only a 1300cc so this is a overkill BUT i also put a turbo on it at the same time so i had to oversize it to help the turbo spool quicker hey, not that I know much about turbo's but wouldn't the turbo spool quicker if it was a smaller diameter pipe? Smaller pipe would have more pressure its all about differental pressure. you want as much pressure as possable before the turbo and as little pressure as possable after the turbo. do some research.... the info is out there Quote Link to comment Share on other sites More sharing options...
Sparkle Posted December 13, 2005 Share Posted December 13, 2005 old guys that know their shit rule. Ive got a twin 2" system, with factory resantor and 2 cobys per pipe, tis loud and a bit too drony, but ive had it like that for bout a year and a half now and im used to it, my mechanic is keen to change the two rear cobys to something a bit more quiet, but i like the bark it has, but wud be cool to get ride of the drone, ask my backseat passengers Quote Link to comment Share on other sites More sharing options...
2FKNLO Posted December 13, 2005 Share Posted December 13, 2005 yeh i'd be keen to get the deep note on my esky too..which will be a while HAHA Quote Link to comment Share on other sites More sharing options...
RT Posted December 13, 2005 Share Posted December 13, 2005 its all about differental pressure. you want as much pressure as possable before the turbo and as little pressure as possable after the turbo. do some research.... the info is out there that not just the case bro, an exhaust on a turbo car works in the same way as on a n/a car. Yes you should have it a bit bigger but too big and you will suffer the effects of not enough back pressure just the same as anyone else. By your theory if you had no exhaust after your turbo it would be quick as and this simple isn't the case. 2.25 is too big for a 1300 turbo or not. Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted December 13, 2005 Share Posted December 13, 2005 DELETED Quote Link to comment Share on other sites More sharing options...
TygerTung Posted December 13, 2005 Share Posted December 13, 2005 its all about differental pressure. you want as much pressure as possable before the turbo and as little pressure as possable after the turbo. do some research.... the info is out there that not just the case bro, an exhaust on a turbo car works in the same way as on a n/a car. Yes you should have it a bit bigger but too big and you will suffer the effects of not enough back pressure just the same as anyone else. By your theory if you had no exhaust after your turbo it would be quick as and this simple isn't the case. 2.25 is too big for a 1300 turbo or not. On a turbo car you actually want as bigger exhaust as possible, you'll notice all the turbo drag cars etc don't really run an exhaust. You don't want any restriction after the turbo, this will restrict flow through the turbine and reduce performance, and I have talked to many people, and putting a bigger dump pipe and exhaust DID make their turbo spool earlier. It's different on NA cars to turbo cars, when I had no exhaust on my cordia turbo once I put the engine it, it was much faster than when I got the exhaust welded on. Quote Link to comment Share on other sites More sharing options...
Stacov Posted December 13, 2005 Share Posted December 13, 2005 on my pinto ive got 2.25 inch exhaust off the extractors a zortex sports box before diff and a coby after the diff sounds nice on idle but when ur driving dont really hear it intill the car hits 4000+ rpm heh all up cost $800 from pitstop thats moding my extractors aswell abit pricy and im still thinking of changing the coby for a big bore or straight pipe to make it abit louder Quote Link to comment Share on other sites More sharing options...
corrupt Posted December 13, 2005 Author Share Posted December 13, 2005 yeh, im thinking of having this setup on my pinto, 4-2-1 extractors, 2" piping, dumpy big bore at the end, im undecided what to put in the middle as of this stage, i might just keep the original one in. Quote Link to comment Share on other sites More sharing options...
atropine Posted December 13, 2005 Share Posted December 13, 2005 lols at tygertung thinking hes smarter than RT.. Quote Link to comment Share on other sites More sharing options...
Toucan Posted December 13, 2005 Share Posted December 13, 2005 On a turbo car you actually want as bigger exhaust as possible 52" piping?? Careful how you word things or you might sound like a meataxe Its not a case of biggest size possible its about getting the mix right as has already been mentioned. Small enough to allow it to spool faster and large enough to not restrict it once its at maximum boost. Quote Link to comment Share on other sites More sharing options...
HUNTD Posted December 13, 2005 Share Posted December 13, 2005 The Cunter has 1 3/4" pipe all the way through with a dynomax muffler. Sounds allrite, not too loud, not to droney. Cost me 380 all inclusive Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 its all about differental pressure. you want as much pressure as possable before the turbo and as little pressure as possable after the turbo. do some research.... the info is out there that not just the case bro, an exhaust on a turbo car works in the same way as on a n/a car. Yes you should have it a bit bigger but too big and you will suffer the effects of not enough back pressure just the same as anyone else. By your theory if you had no exhaust after your turbo it would be quick as and this simple isn't the case. 2.25 is too big for a 1300 turbo or not. i take it you've never taken the exchast off your car and gone for a drive then... when you do u'll notice how much earlier the boost kicks in. eg my two rear mufflers on my 1300 are removable (padock days etc...) and it boosts way quicker when not running those on there. not to mention i run a vf10 off a 2l subie on my 1300 and it spools nice an early. talk to some people that build race cars and see what they say. Quote Link to comment Share on other sites More sharing options...
durty Posted December 13, 2005 Share Posted December 13, 2005 starlet = standard exhaust but with empty cat converter Quote Link to comment Share on other sites More sharing options...
RT Posted December 13, 2005 Share Posted December 13, 2005 talk to some people that build race cars and see what they say. LOL. whatever man. Keep reading your glossy magazines eh. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 lol magazines... u think i have time to read that crap or money to waste on them Quote Link to comment Share on other sites More sharing options...
RT Posted December 13, 2005 Share Posted December 13, 2005 asumptions as to how you have time to write crap but not read it.. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted December 13, 2005 Share Posted December 13, 2005 asumptions as to how you have time to write crap but not read it.. work time now home time is busy time Quote Link to comment Share on other sites More sharing options...
corrupt Posted December 14, 2005 Author Share Posted December 14, 2005 ok, i went to the exhaust shop, got all the other shit i need for my exhaust. i got a proper barrel muffler which is offset, but just like a coby inside, some bends, and an adaptor so i can weld the bigbore on the end. it better be good when i weld it all up. my system, will be 421 extractors, 45degree bend, 2" piping to my new muffler, 2" piping back to just before the diff, original 1.75" bends over the diff, then my 2.5" inlet bigbore at the end with 4" dump tip hope it isnt too loud but Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted December 14, 2005 Share Posted December 14, 2005 what that cost u? Quote Link to comment Share on other sites More sharing options...
corrupt Posted December 14, 2005 Author Share Posted December 14, 2005 got the piping free, dumpy bigbore was 148, the u bend was 25, the adapter was 15, and the muffler was 135. so that comes to a total cost of $323 and ill be attempting all the welding myself Quote Link to comment Share on other sites More sharing options...
