WildPlumDx Posted September 25, 2005 Share Posted September 25, 2005 hey got a ticking noise when my utes running and i pulled the rocker cover off and pulled the coil out and cranked her over till the oil was comming out the top of the valves but the front two valves over piston 1 the exhuast one wasnt bring oil up thru the top of itself lubing itself as such all the others where would this be my ticking problem??? dont have any idea about hydraulic lifers! cheers! Quote Link to comment Share on other sites More sharing options...
Defcon Posted September 25, 2005 Share Posted September 25, 2005 I was told of a little trick by a mechy to sort out ticking tappets, Put a table spoon or 2 of ATF in the oil, and it puts a bit of preasure on them. Def' Quote Link to comment Share on other sites More sharing options...
Jonny Posted September 25, 2005 Share Posted September 25, 2005 Whats ATF?? Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted September 25, 2005 Share Posted September 25, 2005 auto trans fluid Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted September 25, 2005 Author Share Posted September 25, 2005 oh aye sweet i got some of that! some stuff u use in power steer hey ? red stuf? wicked! i'll try it thanks! Quote Link to comment Share on other sites More sharing options...
esky boi Posted September 25, 2005 Share Posted September 25, 2005 Interesting.. is that only for hydraulic lifters or? Quote Link to comment Share on other sites More sharing options...
Ogre Posted September 25, 2005 Share Posted September 25, 2005 meh, the 4g63 and 4g52 and 54 suck when it comes to tappy tappets. Ive tried EVERYTHING!! Quote Link to comment Share on other sites More sharing options...
esky boi Posted September 26, 2005 Share Posted September 26, 2005 meh, the 4g63 and 4g52 and 54 suck when it comes to tappy tappets. mm, same with Pinto's Quote Link to comment Share on other sites More sharing options...
lowlancer Posted September 27, 2005 Share Posted September 27, 2005 Fully, first thing fuel ever said when he saw my car was "Fuck you need to reset your tappets" So we did, didn't do shit Quote Link to comment Share on other sites More sharing options...
WildPlumDx Posted September 27, 2005 Author Share Posted September 27, 2005 but its not tappets its hydros all i want to know if oil spose to come out the top of all the valves lol pretty sure it is all the others are doing it except two front ones! oooh sounds like everyones got this problem hey! Quote Link to comment Share on other sites More sharing options...
phillip@premierauto.co.nz Posted September 28, 2005 Share Posted September 28, 2005 sounds like the little hole is blocked and not letting the oil through, try doing a service putting in some good quality oil, if still no good top up oil with some PRO MA, lifter treatment avaliable from PDC 021892179 or we have it at work. Quote Link to comment Share on other sites More sharing options...
anglebox64 Posted September 28, 2005 Share Posted September 28, 2005 if it still makes a tappy noise your hardenig on the metal face of your rocker has gone would need replacing as the same for 2ltr pintos the rockers wear out and need new ones Quote Link to comment Share on other sites More sharing options...
durty Posted September 29, 2005 Share Posted September 29, 2005 I was told of a little trick by a mechy to sort out ticking tappets, Put a table spoon or 2 of ATF in the oil, and it puts a bit of preasure on them.Def' would this help fix the noisy tappets in my starlets 4k? Quote Link to comment Share on other sites More sharing options...
TygerTung Posted September 29, 2005 Share Posted September 29, 2005 No you need to adjust them Quote Link to comment Share on other sites More sharing options...
durty Posted September 29, 2005 Share Posted September 29, 2005 sweet as, thanks, gotta do that this weekend then Quote Link to comment Share on other sites More sharing options...
Hemi Posted October 1, 2005 Share Posted October 1, 2005 ahh hydruclis lifters ...awesome but ahh crap ...lol i was putting a head back together and craked 2 of the lifters ...my bad when re-building and engine makes sure none of the pistons are at tdc Quote Link to comment Share on other sites More sharing options...
Ned Posted October 1, 2005 Share Posted October 1, 2005 mix 4 parts oil, and 1 part saw-dust. put in engine, no more noise!!! note; i will not take any responability for any engine dying after putting this mixture into either engine, or gearbox (works in both) testing has shown that engines generally do not live for more then 20 minutes! if they go at all. great for when you wanna sell your car or bike Quote Link to comment Share on other sites More sharing options...
