phillip@premierauto.co.nz
Everything posted by phillip@premierauto.co.nz
pay the money and put a pedal box from palmside in, run a mininum of two piston calipers on the front, 4 piston would be better, EBC pads and motul fliud, ok for escort, with drum brakes on the rear, mk2 sport or capri drums all good with no booster, only one race car we look after runs a booster setup.
this is not a race meeting, it is a sprint meeting, wich means there is about 10 cars on the track at once spread out in about 30 second intervills doing about 6 or 10 laps then the next group goes out. it is good for testing or learning, any cars are welcome, you dont have to have a ford, but you do have to have a minimum of a club sport licence, can be purchased from motorsport nz, check out the motorsports web site for licence fees and application forms.
help me rebuild a sierra engine
phillip@premierauto.co.nz replied to mk2_escort's topic in Tech Talk
the best thing when building any engine is cleanness. make sure everthing is clean and a tidy, one piece of dirt under the bearings when they go in will distroy them, use a good quality assembly lube and set the cam up properly, you can run 40 mm sidys and extractors with a standard cam set properly with adjustable cam wheel very well. -
nitespeed drags meremere friday 18th nov
phillip@premierauto.co.nz replied to AE25's topic in Upper North Island Region
thats it for us, done our dash coming up to busy part of season getting rally cars ready for events in new year. -
whers the video. ps had a spare helmet there ya just got to ask. -
1600 capri clutch plate will do the trick.
the cam must contact the rocker in the middle of the pad aswell or the two of them will wear away very fast, this must be checked with ground camshafts.
they dont fit, to much off set.
the atlas getting to old now, second hand parts are all worn out and new is soooo expensive. put in a 3.5;1 ratio on a quafe atb lsd unit and crake test the axles, wont have a problem with it.
can you send me the pics of niscort down the strip, cheers. -
pretty close, 13.6. got to forth place in class c3 turbo 2 wd, not a bad night for us, sham about the time it took to get through all the cars early in the evening i was actually thinking bout going home 10.00pm then we just kept winning races untill final four and got beaten. -
im going to run niscort down their and see if we can under 13sec. -
2 liter cortina engine into mk 2 escort
phillip@premierauto.co.nz replied to R100's topic in Tech Talk
i have a sump i could sell you allready to go. -
Bruce from manon butler motors has all the bits for pinto engines sohc and dohc.
did the smoke smell like oil, usally oil smoke is blue, brake fluid or diesel can produce white smoke, check the smell of the smoke and your brake fluid resourvor.
ive got a sump and some mounts avaliable.
i woundnt have a problem isuing a warrant so long as it works correctly.
they been order allready, waiting for them to turn up because there is some people going out racing this weekend instead of watching bathurst. made basterds.
the drums of fuel only last a couple of days around here then ther normly all sold out.
i can supplie some vented rotors that bolt streight up to the mk 3-4 cortina hub and soom good pads to help with the heat.
i took 5 drums with me this weekend, used 2, will use next three drums at next weekends event.
