was thinking of blow or suck trough injection a bit hard as stuff all room in the anglia engine bay lol aand cheap cheap but have good mates that can welp alloy etc so not such a mission anyone got a cheap charger they want to sell me hehehehe
hi all what im thinking of doing is getting a supercarger off a japper ie toyota or somthing as i want to put it on my anglia its a cortina 1500 motor so can anyone tell me what i shoud think of doing to make it work cheers cliff
if it keeps on running it is bad for your motor as it can make it run backwards and will dry the bearings out which will cause unnessasery wear on big ends and mains which will in the long run cause bearing knock then buy buy motor so best to ceck carb mixture and dial in your cam if its got a lumping one good luck any ways mate go the ford105e ANGLIAs
steel crank balanced ,blue printed&shot penned rods ,capless rings ,forged pistons ,ARP bolts ,and one big FORD badge on the front lmoa or a datsun a12 motor yeah
shit should i have my car certed aswell its got 15x6s on alround with modified motor blah blah blah lowwerd etc on my shity anglia and never had any probs getting a wof well thats what mates are for nudge nudge but there are some arse hole coppers out the aye that would love to throw the book at ya
yeap all cortina heads fit as well as escort mk1-2 only difference is the ratio as someone else has said also diff heads fit anglias so we on to a winner yay a 3.54.1 ghia/1600 sport diff would go great im my anglia hint hint any out there if so how much
if it stops raining i would go out but my car leaks lol
i may take the anglia out as it gets parked up next week
for a weee while lmao no licence time again
if it still makes a tappy noise your hardenig on the metal face of your rocker has gone would need replacing as the same for 2ltr pintos the rockers wear out and need new ones
yea mate had lifter come away from roker arm and hitting rocker cover but if its realy bad buy buy bottom end big ends make a big knock knock when there stuffed dont over rev it or it will say boo out the side off block or sump best to drian oil and strip down id say few hundy for complete rebuild
has anyone done a conversion on a anglia 105e from drum to disks as im wanting to put my mk2 struts in and it looks like a b***h too do any hints i have the mk2 bottom arms as well also any one got a worked cam for a 1500-1600 ford ohv motor
has any one done a conversion on a anglia to disk brakes any clues too what i should use for struts i have been told mk2 cortina struts and lower arms any ideas guys thanks
