Guest Scheme Posted August 24, 2005 Share Posted August 24, 2005 Hey guys, what do you consider the best liable options when it comes to DIY paint stripping, preferably down to bare metal. Sand paper is the obvious choice, which I have done a panel with, but it takes one hell of a long time. I tried the heatgun on a bit, which actually rips it off pretty fast, but was wondering if it would damage the metal? The other option would be to buy some sort of liquid paint stripper? You thoughts appreciated. Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted August 24, 2005 Share Posted August 24, 2005 I spose the best way would be electric sanders, heh. Quote Link to comment Share on other sites More sharing options...
lowlancer Posted August 24, 2005 Share Posted August 24, 2005 I used aeronautical stz paint stripper on my bonnet, worked a treat. The weak shit at repco etc is shit. Quote Link to comment Share on other sites More sharing options...
solidstripe Posted August 24, 2005 Share Posted August 24, 2005 Soda blast!! Not DIY (i think) but works a treat!! Quote Link to comment Share on other sites More sharing options...
Gaz Posted August 24, 2005 Share Posted August 24, 2005 Bead blast it. Will take out all the bog mind you. Quote Link to comment Share on other sites More sharing options...
davidian Posted August 24, 2005 Share Posted August 24, 2005 DIY? just rock it with a sander using 80 or soumething roughish after youre done wet sand it by hand. can get bare metal if you go hard, but probably dont need to unless its a shocker Quote Link to comment Share on other sites More sharing options...
RT Posted August 25, 2005 Share Posted August 25, 2005 walnut blasting... yep you heard me.. walnuts. Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 25, 2005 Share Posted August 25, 2005 eh?? who does that and what effect does it have Quote Link to comment Share on other sites More sharing options...
davidian Posted August 25, 2005 Share Posted August 25, 2005 you get a lovely fine dented look al around Quote Link to comment Share on other sites More sharing options...
two_days_late Posted August 25, 2005 Share Posted August 25, 2005 use an orbital sander, never use a belt sander cheers Matt Quote Link to comment Share on other sites More sharing options...
RT Posted August 25, 2005 Share Posted August 25, 2005 they blast your car with chopped up bits of walnut.. it's supposed to be much softer than bead blasting or sand blasting as the walnut grains disintergrate on impact Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted August 25, 2005 Share Posted August 25, 2005 is there a sander i can buy to hook up to my compressor? if so how much are they aroundabouts? or shud i not be a lazy cunt and do it by hand Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 25, 2005 Share Posted August 25, 2005 orbital sander Quote Link to comment Share on other sites More sharing options...
Guest WESTCORT Posted August 25, 2005 Share Posted August 25, 2005 yea well i had no idea what that was, how much do they go for? and what sorta hp or psi does my compressor need to be spitting? Quote Link to comment Share on other sites More sharing options...
Guest escort_boy Posted August 25, 2005 Share Posted August 25, 2005 something decent if u are going to be running it constantly and they are about 80 i think for an average one Quote Link to comment Share on other sites More sharing options...
v3k Posted August 25, 2005 Share Posted August 25, 2005 use a paint stripping disk for a grinder. Or a flexi sanding pad for a grinder. Good as gold at tearing paint off Quote Link to comment Share on other sites More sharing options...
Guest Scheme Posted August 25, 2005 Share Posted August 25, 2005 i tried a heatgun, and it actually peals it off pretty fast, is there only cons to using a heatgun? Quote Link to comment Share on other sites More sharing options...
Rusted Posted August 25, 2005 Share Posted August 25, 2005 Not sure about the heat gun, have to many layers of paint on my datto. 3M paint stripper pads for drill or grinder, Makes life REAL easy. cost is about $16per pad or $22 for the twin pad. Quote Link to comment Share on other sites More sharing options...
mutiny Posted August 25, 2005 Share Posted August 25, 2005 dont use a heat gun! even using a orbital sander in the same spot for to long can heat it up enough to warp the metal Quote Link to comment Share on other sites More sharing options...
Bistro Posted August 25, 2005 Share Posted August 25, 2005 use a paint stripping disk for a grinder. Or a flexi sanding pad for a grinder. Good as gold at tearing paint off ^^^ That works a treat. Quote Link to comment Share on other sites More sharing options...
