danger Posted May 25, 2005 Share Posted May 25, 2005 Recently my 1300 xflow died mysteriously. Still dont know why but suspect the rings all died at once. Anyhow iv got it apart and im looking at a few mods. already has a cam and extractors and iv just finished porting and polishing the head, what else can i do cheaply that would boost power. I dont want to spend alot of money as my mercedes is still off the road. Cheers Quote Link to comment Share on other sites More sharing options...
davidian Posted May 25, 2005 Share Posted May 25, 2005 youve done the carby? not much else i can think of you can do without going at the bores and such.... you can always stick in larger valves and double valve springs Quote Link to comment Share on other sites More sharing options...
RT Posted May 25, 2005 Share Posted May 25, 2005 did you port the head properly of just wizz around it with a drill.... if it's the latter then it will might cost you power rather than produce it. I wouldnt bother going for big valves etc if you don't wanna spend money. index and side-gap your plugs and advance your ignition is all I can suggest to grab a few free horses. There's a article on my site about side-gapping plugs. Quote Link to comment Share on other sites More sharing options...
davidian Posted May 25, 2005 Share Posted May 25, 2005 for a price of doing a couple of simple things, you could just pick up a standy secondhander pinto and chuck it in Quote Link to comment Share on other sites More sharing options...
Jerm Posted May 25, 2005 Share Posted May 25, 2005 Its not that easy to put a pinto in... its a bit of messing about... driveshaft.. sump.. throttle cable.. exhaust... fuel line.! not to mentoin cost od cert...... Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 25, 2005 Share Posted May 25, 2005 Pinto aint that hard jerm RT, can you chuck up the link on side-gapping the spark plugs? Quote Link to comment Share on other sites More sharing options...
esky boi Posted May 25, 2005 Share Posted May 25, 2005 Dont worry RT, found it Quote Link to comment Share on other sites More sharing options...
danger Posted May 25, 2005 Author Share Posted May 25, 2005 Yeah i just had a crack at it with a drill, nothing too drastic just cleaning it all up and getting rid of the burrs and lips. Cheers RT i'll look into that. its got a standard carb on it at the mo but im looking at either slapping a webber on it or trying to get or make a manifold to fit a set of 11/4" twin S.Us iv'e got. What i really want to do is make a manifold for quad S.Us. hate to think how hard itd be to set up and tune tho. Whats the story with 1100cc pistons etc? that just raise compression? what should i do to the ignition? Quote Link to comment Share on other sites More sharing options...
RT Posted May 25, 2005 Share Posted May 25, 2005 quad cabs? on a 1300?... hmmm I think that could be a little overkill. I probably would bother doing piston swaps etc.. if you want significantly more power just put a 1600 Xflow in there. The're exaclty the same only a cm taller. Everything will bolt up and and you won't need a cert or nothing. If you start doing too much to the 1300 it will get out of hand. Do this, do that.. then you need to do this etc etc and $$$$ and it's still a 1300. Mate of mine went down the same track on his Toyota 4K. He started just doing a few things and before you know it, it was blue-printed and engineered etc etc and cost heaps in the end. Sure, it was a weapon of a 1300.. the fastest 1300 I've ever seen. But it was still a 1300 and a waste of money when he could have done all that to a bigger engine for way more power. Quote Link to comment Share on other sites More sharing options...
danger Posted May 27, 2005 Author Share Posted May 27, 2005 No cert? Ok thats news to me i figured itd require one Quote Link to comment Share on other sites More sharing options...
RT Posted May 27, 2005 Share Posted May 27, 2005 well 'technically speaking' it does. But since they are identical, it would take one very nosey wof man to notice the head being 1cm taller than the last 1300 escort he'd looked at... Quote Link to comment Share on other sites More sharing options...
Hemi Posted May 27, 2005 Share Posted May 27, 2005 yea my esky is ment to have a 1300 and it has a 1600 and it fly's through wofs the engine are exactly the blemin same man except the block stamping and longer stroke Quote Link to comment Share on other sites More sharing options...
danger Posted May 28, 2005 Author Share Posted May 28, 2005 well i might just have to bend the rules a little then... Quote Link to comment Share on other sites More sharing options...
Guest Demonmk2 Posted May 29, 2005 Share Posted May 29, 2005 yeah the guy who i brought my escorrt off has a 1300 worked sprint engine worth 3k or somthing he took me 4 a blat in that and fuck it goes for a 1300 :S it would kick my ass and im 300cc's more than him pretty funnyn driving buy when u see a 1300 fly past you Quote Link to comment Share on other sites More sharing options...
zep Posted May 29, 2005 Share Posted May 29, 2005 Yeah, but you don't know its a 1300 and therefor assume its not! Quote Link to comment Share on other sites More sharing options...
Jerm Posted May 30, 2005 Share Posted May 30, 2005 3k not much fo an engine.. especially if you are payingsoemone to buldit Quote Link to comment Share on other sites More sharing options...
Guest Demonmk2 Posted May 30, 2005 Share Posted May 30, 2005 umm it had its engine code or what ever you call it on the cert and stated it was a 1300 it was in his car and why would he lie to me to say its a 1300 no big bonus in saying its a 1300 rather than 1600 :S Quote Link to comment Share on other sites More sharing options...
atropine Posted May 30, 2005 Share Posted May 30, 2005 have you been listening to the convo at all? were saying that you can put a 1600 in a 1300 and not get it certed as theyre so similar.. basically.. my 4dr has 1.3 on its rego and is a 1600 the guy i bought thought it was a 1300 too Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 30, 2005 Share Posted May 30, 2005 You're right, you might be able to trick the WoF man, but if you have an accident you're not going to trick the Insurance assessor who will happily null and void your policy for having that wrong capacity engine in there. Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 30, 2005 Share Posted May 30, 2005 You really think they would check engine codes and such??? Quote Link to comment Share on other sites More sharing options...
