Everything posted by sr1600
Got a set of gto front brakes chilling in a box at home if you need any measurements
You would burn your fingers..... Reality is you would end up with something that doesnt run true even if you could manage to do that......
Yep good to hear Was it the intake that put the pressure outside the mapping? assume you run steel seals due to the class?
Rumour has somewhere around the 100 mark + the full scale 1:1 model above made it in all her glory. Was an awesome day so much 2 stroke mix and there was a real mix of new and old, (was cool seeing the older blokes wandering rocking their oldschool mazda club hats) good fun out on the track and a pretty good attitude all round Thumbs up
Haven't decided yet , either in the morning or later tonight
Leaving before 7 also
Good work Gaz, should be a good little project...when do you want me to pickup the last one you were working on?
Heading south should be a good day. Hope the small minority that cant go a day without drinking stay home /dont cause any trouble. Be nice to have a successful day be nice to add another local advent to the calender
id just machine up thick crush tube that locates in the big hole but is slighty shorter so it all pulls up tight and run a 8.8 bolt right through id do a crush tube in the bottom hole as well between the mounting plates and 8.8 nyloc Options
Always wanted to spin that motor to 9000rpm with that flywheel just to hear the noise......... Let us know when your ready.
Sad news brent alot of work/preparation went into ensuring a competitive racecar this year and what a shame to be let down at this stage especially so early in the season... Let us know if you need anything sorted/can help down this way
Love them rx2 sedans....... Nice work...going to run motor that in the car?
Seems a shame to paint all that work now... Paint the roof/Clearcoat the sides
K-TOWN stylez........................ Or Overbored and sleeved
Plan is to go with birdman...... But if can sort my rear pcd will take mine also and make some other bits up
Booked this weekend off , who else is going down? Might even get old smokey out of retirement...............................................haurangi
Photocopy of his reciept ok?
Im seeing a drip/spare parts catchment tray...................................................haha Love your work...............................
- 497 replies
Yeah some nice work gone into this thing , even some others would never pickup anyway Still to this day remember the pictures showing the merging of a rx2 center and rx7 outers to make the diff................. Wonder if I could pull this of with a series 3 4x114 diff , but god damn they are expensive.....cheaoer to shorten hilux but where im going i dont need it.
http://www.trademe.co.nz/motors/car-parts-accessories/performance/other/auction-841675565.htm 1500 OA is about right for you
This is the only modified one I can remember............................./ wanted to remember
Can see where this is heading
No probs ended up being to deep and hiting the steering arm so went with a bmw disc in the end. Having them spun down to fit
Get your wide coal chisel out or similar blunt wide object Take the guard off, stick it in that swage line from the inside an give it the beat till its straight. Guessung you will end up with a straightish swage and a dent either side that would need shrinking then. Shitty advise really be either better or completely rooted haha
- 24 replies
- dent
- panel beating
(and 1 more)
Tagged with:
Bit of an odd request but does this have the 289mm diameter front disc? Im after the pad contact width out of interest....
