Everything posted by Bling
Will they actually let you take one in?
Mr and Mrs Sheepers put themselves into debt for the rest of their lives.
Bling replied to sheepers's topic in Other Projects
Looking good! What sort of time frame have they given you for the 'reno'? I especially like the blocklayers PPE. -
Jesus! That would take a shit load of force to do that damage!! Refund time.
Looking good man, a bit more involved than you first imagined?
Ted Huang's Starorion - 0R10N's 1988 Mitsuhishi Starion
Bling replied to xsspeed's topic in Project Discussion
Looks pretty bad inside, so could just be a matter of time before it splits somewhere else? -
Lookin hawt. I got my Corolla boot seal from ParaRubber Blenheim Rd, if that's any help.
Phwoar, so red and shiney!
Pretty sure I can make 1st Saturday, 3rd, not so much. Do you need any tools bringing along?
I feel like there should be at least a dozen progress photos between those two. Post em up!
In regards to the clunking, are you sure the piston rod nuts are all the way home? I've had it before where the piston hadn't locked into the top hat correctly and so the piston was turning when I thought it was locked in place. Meant clunky noises. Popped the nuts off, and realigned the piston rod into the top hat (it had a cut out, hadn't noticed it at first), this locked the piston and allowed it to be properly tightened. You've likely already got that sorted, but just thought i'd mention it in case. Or your setup may not be the same. I'd just check by tightening it and checking the piston isn't turning.
Got any tech questions? Spam thread is that way ->
HAH! I just came to post that. Nice work man, I can't even keep up with the updates, let alone that work rate!
Impressive build!
Yeah in many cases the suspension on super low cars is setup for looks, so performance isn't the main priority. With the likes of weld on sleeves, the springs used are much smaller diameter, so they can sit much lower than factory perches. 30mm of extra spring length will always be good. If I was going super low, i'd go weld on stuff for sure, you can set it up exactly how you want. Using factory perches does limit you quite a bit in comparison. From the photo, it looks like you could even get more than 30mm lower if you went aftermarket weld on sleeve option? Just my opinion though.
Paint it black
That's all good then, should be able to come for a squiz before I go back to work. Will see how house chores go here.
Got a water heater location sussed? (chuck a pic up) Good idea to have a bunch of timber in the wall for fixing for that. 200mm wide by 1m or so, to allow for the height to be adjusted to suit, water heater will be 600mm high roughly. Pics look good when clicked, a lot of work involved eh!
It will be sweet. We have that drill at work, goes hard 4 wot it is. Legit. 2ah is fine too. I use 1.5-3ah at work, all do the trick. I only have a brushed version at home, and use it for all sorts. 18v is way overkill for small home odd jobs. And yeah it does normal drilling. Two speed / Three modes, drill, screw (clutched) and hammer drill. I'm a fan of their gear. With that said, you can get some decent DIY level gear for less moolah from the likes of bunnings / mitre10 these days. So it could be worth seeing what options they have. I'm not talking ozito either. Milwaukee is great if you plan to buy other tools in the range though, I probably have 5-6 tools on the m12 system now.
Are you talking about on a chassis or something you can't put in a booth? I had a supercheap handheld gun in a cabinet, never had any issues with it. IT was just a basic pistol + suction pipe setup. If you're doing it outside, then you'll want to have some respirator half mask or similar if using sand. I had some pink garnet in my cabinet as I don't think it's as bad for you as sand. But it was a sealed booth, so don't take my word on that. tl;dr even basic sandblast tools work, it's just sand blown by air after all.
