Everything posted by Nominal
They are a good idea though, and having a rules argument with your certifier may not be a good idea.
Good to see you got there, only a year or so late Nice work though.
Blue windows in gassers is a thing @Gasser
Just buy the curved set at the cheapest place then weld a bit of angle iron across the front and back so that don't do that ^^^ Then cross your fingers and push.
There's nothing in the LVVTA standard https://www.lvvta.org.nz/documents/standards/LVVTA_STD_Wheels_&_Tyres.pdf about locating rings so you should be fine.
I didn't need them when getting a cert.
They will all be similarly crappy.
Nominal replied to azzurro's topic in Project Discussion
Won't it need some rust repair now after being out in the rain? -
Got spiders? I doubt that a swap to a Toyota or Nissan chassis will fly as mod-prod. The example in the sheet you linked if for an in-brand swap. See here for example http://lvvta.proboards.com/thread/541/modified-scratch-built-chassis
Depends what you want. Bits of old cars and washing machines etc can be used for hacking around, but you have to clean of the paint etc first. I've bought full sheets from Steel and Tube in the past, but you need something to cut them up. The zintec / electogalv coated steel stores better as it doesn't rust but again needs to be cleaned off before welding. https://steelandtube.co.nz/catalogues/steel-product-guide Last time I needed some I went to a sheet metal fabrication place and bought some smaller pieces (e.g. under 1m2) in different gauges. They were happy to help. You probably want 18g ~ 1.2mm for car panel work.
I've had good luck using the Dorman catalog (pdf https://www.dormanproducts.com/flipbook/dorman/automotive-hardware/2006-automotive-hardware.pdf) Find the stud then look up the application by part number.
Nominal replied to h4nd's topic in Other Projects
It's a bit lame when factory parts don't meet the certifiers requests.- 1289 replies
Te Urewera Undertaking, 2019 Nov 29th, 30th, Dec 1st.
Nominal replied to johnnyfive's topic in Upper North Island Region
Well, lets see from the experts, @KKtrips may have an opinion
I'd be a bit surprised if that would pass a cert check. Usually welding in the steering assembly is discouraged.
Only Nissan RB Barries could talk about oil pumps for 379 pages!
It depends on when it was first registered in NZ: - before 1 January 1991 -> No rears required - between 1 January 1991 to 31 March 2002 -> Rears required - after 1 April 2002 -> No rears required https://vehicleinspection.nzta.govt.nz/virms/in-service-wof-and-cof/general/vehicle-interior/seatbelts-and-seatbelt-anchorages
I've done that Nissan swap on my Morris Minor, pretty easy and haven't touched it for 15 years since. I don't know if the Hillman version of the Lucas dizzy has the same external dimensions though.
@Mourning Cupcake I'll there so long as on-call activities don't go pear-shaped. -
More a shake off than a shake down? -
Weld a bolt to it, heat will help loosen it up.
Yeah, nah
