Everything posted by kyteler
There was one at the Riverton Car Show the other day. I hung around for a little at it hoping to catch the owner and share Prince based yarns but sadly no dice. I posted a picture of it in the spotted thread. It was legal but humorously rough and ready.
kyteler replied to TimShadboltfan27's topic in South Island Region
Yeah, there's a carpark on the north side and I doubt the garage will be open at that time of the week, maybe though, but plenty of space there regardless.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Black smoke would be over-fueling, greyish smoke is more likely an oil issue? It's not got a ventilation/re-circ issue does it?
Yeah I was just going to take the FD because FD and I have nothing else available at the moment- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
Look up the actual tyre manufacturer specifications. I quickly looked it up on my phone and the toyo one I found suggested 4-5" rim width. So your ones might luck out with an extra half inch? Manufacturer specifications trump wof inspectors.
Google says yes.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
This satdee? Shouldn't be a problem I thiiiink. Had to work satdee been hoping to not have to do the same again. Run to Riverton is always nice and easy.- 1055 replies
- meat raffle
- meat raffle
(and 1 more)
Tagged with:
100cc too few to excite me, tbh. Ain't no wolf,
I would err against a metallic colour and also against body coded steels if I'm honest. If you're white roofing it then steels to match the roof would look good but I'm not a huge fan of colour coded wheels to cars combos. Have fun though regardless, looks like a sweet lego technics set you've got yourself.
I believe this has been gone over before and the offset is measured at the cert but it is not on the tag although because the data has been recorded it can be investigated if required. I could be confusing that with something else in the process though. I'm sure clint will confirm or deny.
Fucking swoon central mate. Props to you.
Leave a ram watching enthusiast the keys to the mighty Avenger? You'll be lucky, Trev.
Doesn't the letter of the law state it needs cert. Probably why Don says it does. Unless the insurance company will write it in a letter then I wouldn't believe them for a second.
I like 'em. They almost need to be bigger at the back though? 17/18 stagger? Still. I contemplated them for the seven but they'd need a more convex look and the right offset.
Yeah, likely a re-vin
EA-B-D is the same car, hell even EF and EL are basically the same with a facelift.
Easily, I imagine. This one alone is proof of both lower kms and same height standard. https://www.trademe.co.nz/motors/used-cars/ford/auction-1364185752.htm
Guards, etc.
You'll have to do some adjustment to get those bits to fit your PFL.
If you can turn the engine bay into an S30 one you'll definitely be doing well...
The +10s look a better fit.
Put a lazy BB in it.
305s don't get max $$
Bad freaking ass
Sounds like it's potentially frame twist from a few posts in this and the easy "fix" is to slam a spacer in. I lol'd. http://67-72chevytrucks.com/vboard/showthread.php?t=512567
