kyteler
Everything posted by kyteler
  1. Are you parting out that other one? I have a mate who may need some bits..
  2. http://www.supercheapauto.co.nz/Product/Water-Temperature-Sensor-Adaptor-38mm/155259 Plug adaptor with bolt if necessary. + Cut this to size. http://www.supercheapauto.co.nz/Product/Mackay-Top-Hose-CH1101/102218
  3. Wouldn't it be easier to get a 90 in rubber then a lipped straight to connect the two rubber bits? Even just a cut off section of pipe would work OK.
  4. Yeah they were, my bad. Just googles it now. How would they go legality wise? They seem pretty legit.
  5. I was watching something on pootube the other day and the guy removed all that seam-sealer at joins in the chassis because if he didn't the blaster wouldn't get in behind it. Not sure if this is an issue with sand (I think he was glass bead) but it may be something to consider given that your larger areas of rot have crept in all underneath this stuff and could be hidden still post blasting.
  6. Finnegan has some ones that seem legit on his truck. Will try see if I can find out what they were.
  7. No they're not. The battery should sit above twelve on its own and with the alternator running should be between thirteen and a half and fourteen and a half volts. If it's dropping to battery voltage with the alternator running then the alternator is not taking the load. The alternator not doing its job is the likely cause of the battery going flat and if its been doing it a while then it could have fucked the battery early. Check the basics though. Belt tension and connectors first.
  8. That's a sweet bit of kit but 2K? You could buy an actual hoist for that.
  9. LS-powered, I hope.
  10. Yeah, it says Tanpei Nakata Corporation.
  11. Install Google translate on your phone and there's a camera function that you can hover over the text and it translates it on the fly. Super handy. Used it on my brothers leaf and the old man's Japanese import Audi.
  12. Please be careful getting that down mate. Good job, btw.
  13. This seems like something @Poo may be of assistance with...
  14. Mate, having that sitting up there on those gives me the shits just looking at it. Fuuuuuuuuuuuuuuck that. ..with that said, I would have probably done something similar but because I did it I wouldn't care as much. Can you weld a brace between the two supports? or a couple of them. I'm scared they'll fuck off and fold over if there's some manner of heavy pushing or work on the car but if they're tied together solidly that should help to eliminate that.
  15. That looks a bit yuck under there boss.
  16. Fucking swoon.
  17. What's the width and offset on those standards? They look slick as fuck. Make 'em work.
  18. No bonnet sorry. Put that on my other coupe. Doors, seats, random bits from the three piece chassis.
  19. If you need any parts that I have left over from the sedan I pulled to bits you're welcome to them.
  20. There's a set of 14" tridens on whitewalls at my local hot rod shop for a grand, I kind of want but struggle to justify the price when the only car they'd sort of suit is a daily d21. You might be keen though?
  21. If you could send it down that would be choice dude, I'll message you my addresssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssssss. ssss.
  22. Cheers man. Mine appears to have started leaking and my spare is fucked slash broken somehow that I can't recall why or what for. Definitely keen for one less leaky.
  23. Might be keen on a spare pump if available.
