kyteler
Everything posted by kyteler
  1. Like fuck. LS conversion. Good buy though man, good man.
  2. Giz the deets then At the moment it's in the shed with the intake/exh half undone, I need to fix the massive exhaust leak it has from two missing/broken studs. One of the things I should have checked before I put it in the engine bay, I guess.
  3. A length of chain is better than nuts and bolts as it's easier to remove at the end.
  4. 10 of them, for maximum novelty/humour value. I parked "my" one in there and when I left, there was another one outside, so I stole it. The same thing happened 8 more times.
  5. You'd be so proud, Grumbles, check out my online garage in GTA V.
  6. Walk in to places, have a yarn, that's your best approach.
  7. Clippers? Trim/scrape away as much of the fluff as possible and then you could try to spray some turps up there to soften the glue, let it soak, spray some more, let it soak, spray some more and then let it soak and try wipe it off with some gentle pressure.
  8. You can do it man, I drove to Nationals in P.Norf from Invercargill in an R30 running on 4.75 out of 6 cylinders 90% of the time.
  9. Bravo, sir. Well done. Well done indeed.
  10. You should be able to snag something decent in 13" in 110 for not a lot, simply because it's not the common and more desired stud pattern. These things can work in your favour on YAJ.
  11. Does yours still run 4x110? (I'm sure my brother's old KE25 was 4x110) If so.. PA-FUCKING-CHOW!
  12. Just not with gold centres, because gold belongs on middle eastern grease-balls, not cars.
  13. What direction are you going to head with the wheels? It would look super cool slammed on some uber wide thirteens, those racing forg(?) doodad ones with the conical dished centre.
  14. Austin would win, hands down.
  15. Pictures, BWAAAAAAAAAARRRRRRPPPSSH?
  16. I know I say it every time but fuck me I'm so jealous of you for getting this car.
  17. Steelies is Ariel?
  18. Hah, that will be awesome if he did get a pic of it. This wags has done the Bathurst mission from Brisbane and back two years running. It's the OG OS Bathurst Mission Wagon.
  19. Will be so good to have that completed man and just think, if you'd kept one of your other Datsun projects you could have started on that afterwards! hahaha
  20. You fucking fruit loop. Keep it BMC, I reckon.
  21. They look so good man, awesomeness.
  22. MOTHERFUCKING YEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEAAAAAAAAAAAAAH BITCHES!
  23. Wheel good work there.
  24. Maybe the cause of the surging is the pressure differential due to having no proper roof... ...
