Everything posted by datlow
What sort of compressor? Belt drive i would go with start cap or centrifugal switch
Eastcapescapade #6 2022 November 11th, 12th, 13th
datlow replied to johnnyfive's topic in Upper North Island Region
Citroens got a tow bar right?? -
What difference is this motor to your previous one? Did it have heating issues Remove intercooler and run NA for ease of testing Bonnet open make any difference?
keep cracking windscreens from rocks etc , i see there are 3m type clear products available are they legal in nz and anyone used them?
runx motor any good comes with conveniant transport device https://www.trademe.co.nz/a/motors/cars/toyota/runx/listing/3697331835?bof=pTyUNXXL
Are you using it gasless for panels?
Water cooled turbo?, temp disconnect shouldnt hurt it idling to rule out ? Got a laser temp gun to run over the radiator?
Comacs is cheap for short lengths https://www.comac.co.nz/aluminium-cargo-track-anchors
Pretty sure some used a Radiator shop ? Maybe more for splitting open and removing rust actually
@shizzl Just saw on facebook zerba in manakau has a grx in for wrecking if you need even more parts
Block of timber to go over the intake just incase
20+yr old by the time you import it or own it for 2 yrs in canada should be sweet Unless they change all the rules by then..... /usa has 20yr? rule too so could probably still profit selling it to them
Shit yeah Theres a cast turbo manifold on fb for 150.......
Sounds ideal Is the gts4 gbox same as gtr?
rain, or indicating or turning when it "thinks" you might have left that road all means it just goes blank or comes up with a random amount
I cant imagine it being the make or break to anyone And totally understandable -
Oh yeah, plenty of time to procrastinate Ken -
each one seems to have there own ideas by the looks of it (havent personally taken one through yet) so best ask the one you intend on using im sure some before/during/after photos would be handy though
Borrow petes fezza brakes https://www.instagram.com/p/CeFoyH1OQkt/?igshid=YmMyMTA2M2Y=
Best way to strip an alloy bonnet? Was thinking Paint stripper Will need some sanding too i guess as theres some minor corrosion
It was always like that /so long as it looks good enough for the wof man
Have you heard about the wonderful cooling effects of meth Will it be attending os drags?
Will it start if you spin it? Try both directions
datlow replied to yoeddynz's topic in Project Discussion
Ive got 28mm bends from ali, probably not big swoopy ones for your application tho.. NZ$ 2.14 | 12.7 16 19 22 25 28 32 34 38 40 42 45 48 51 52mm OD Butt Weld Elbow 90 Degree 304/316L Stainless Sanitary Pipe Fitting Homebrew https://a.aliexpress.com/_m0rDWNg
