Everything posted by datlow
Te Urewera Undertaking, 2019 Nov 29th, 30th, Dec 1st.
datlow replied to johnnyfive's topic in Upper North Island Region
thursday night accom available at yours/that the starting point again @johnnyfive? -
will that be the ride height? reckon it would look sweet/impractical(would it even turn?) lowered
nice!, bike shop to change the tyres? what width/size are the rims?
I put my bike rego on hold for 3 months over winter, got the letter saying regos due (they come like a month early) put 3 months on hey presto you get 4months! So I imagine you were in that time frame otherwise it would of back dated to date of purchase?
raumati (kapiti) but i can collect from ferry etc easy -
go on twist my arm, keen as will bring elgrand (doesnt have a tow bar yet tho) but can squeeze 2 bikes in it im sure or if i get a tow bar then 8 seats someone else can drive it as a support vehicle/rwd gravel drifter -
If you’ve got the wheels of for brake pads, then have a look/replace the wheel bearings usually only a few dollars each and again if it’s been sitting they’ll be pretty stuffed/rusty/dry
i thought/found it worked well if you are stuffing around looking at stuff and saw him go past then it meant time to go, he just didnt get to have any/many stops to look about -
Can I reserve a spot if I haven’t purchased a running bike in time -
That’s the spirit what does the kombi top out at? /should be ideal for drafting behind -
Ah I was hoping it was smaller I’d than the usual ali ones as my bikes a twin cylinder 125 so they’re only 27mm ID each (twin pipes) havent found anything that costs less than what I paid for the bike
Oh new exhaust for the gn or? I’m looking for a muffler for my honda
found the fb thing https://www.lvvta.org.nz/documents/safety_alerts/LVVTA_Safety_Alert_01-2019_-_Strut_Spacers_and_Ball-joint_Spacers.pdf?fbclid=IwAR2KfjVtX23-EWNp5DQBVJf-8Cv2sPkCDFmSYR4OILUjzBEMwMB0y1XM34I
mercs have them as standard, can even buy different thickness ones for small height adjustment, but i guess thats factory so?
took 2 weeks for my scooter plates (pretty sure thats standard for others too) just found the auto reply it said 10 day (working i guess) turn around, if your query is urgent phone 0800 366 988 ext 8364 which the confirmation email from tania taite had that as her phone number
good too see your out and enjoying it! how are the ali shocks holding up/ are they too hard or soft etc?
Have heard possible issues from ultrasonic cleaning carbs, it can dry out the felt seals on the throttle and choke shafts and create a air leak maybe try soaking them with oil or grease? To stop air getting in?
fyi it might be changing/have your say/buy some teddies etc @Bling
so list nbc on trademe and sold yesterday (unfortunately only one bid but meh), being collected this weekend so will have some room for the latest purchase so first one is a cb125t with comstars missing/cut up wiring apparently needs coils to run... but has twin carbs second is a cm125t with wire wheels appears to be all there but wouldnt start for previous owner (nothing happened when key turned yet batterys charged so will have to get out the meter) this ones single carb looking on line they seem to be all about the same power (something to do with a 125cc & power limit for this kind of bike?) anyone have any knowledge on these, which ones best motor wise/anyone need parts
What sort of fittings I assume 5/16 is a hose size? Then 1/8bsp is the thread size so just need a 1/8bsp or maybe 1/8bspt (tapper so it has something to tighten up into?)
f1 car only uses 278mm rotors, just get your drill out for more cooling holes (1400 holes now)
if they have enough power to lock up then anything bigger just adds more unsprung weight? A lot of the Wilwood rotors are around 260mm? Brake fades more from the pads/lack of cooling/ cheap brake fluid?
do you like cologne?
brakes will just slow you down man, zorst sounds nice
